Oil Pressure acting funny.
All of a sudden my pressure at start up is 40-45 and when I get on it a little bit it goes to 60-65. I was thinking maybe the oil sending unit but after checking older posts It seems if you have a bad sending unit it tends to peg at 80. Can you have a bad oil sending unit that acts like mine? Maybe a clogged oil filter? Any insight would be appreciated. My car is a 2008.
this
normal pressure at cold start usually at 50 psi and rising with rpm.once warm my pressure at 4,000 + rpm would be over 70 psi with stock oil pump
