ZR1 /( FE5 ) Front Sway Bar part number ???
Old 09-19-2018, 11:09 PM
peanut
peanut's Avatar
Default ZR1 /( FE5 ) Front Sway Bar part number ???
Does anyone have the part number for the ZR1/FE5 front sway bar and bushings? I've looked it up and searched a bit but am very unconfident in the numbers i have. Even searching by VIN at GM gets me what I think is the Z51 front bar.
Thanks!
Old 09-20-2018, 10:22 AM
jaredtxrx
jaredtxrx's Avatar
https://www.cultragfactoryparts.com/...Y4LWdhcw%3D%3D
This is what I found.
peanut (09-20-2018)
Old 09-20-2018, 11:08 AM
old motorhead
old motorhead's Avatar
Received 1,336 Likes on 945 Posts
Check and make sure of what you have now. My 2013 grand sport with mag ride came with ZR1 sways. Found that out during the install process of the "new" ZR1 sways. I had always heard that grand sports had Z06 suspension bits. Not so in my case.
peanut (09-20-2018)
Old 09-20-2018, 01:44 PM
peanut
peanut's Avatar
Originally Posted by jaredtxrx
That's the number I have also but the description does not jive with my notes and leads me to believe it is a listing for the Z06 31.0 mm bar.
uh. .. this is for my C5. I bought it before I realized I wanted a C6 GS convertible Going to make due with it for a year or two.
Did you by chance measure the O.D. of the "ZR1" bar? I think that number listed above is for the 31.0 mm bar which was used on the Z51, Grandsport, and Z06 suspension as I understand it.
Old 09-20-2018, 05:05 PM
old motorhead
33mm front and 31mm rear on the ZR1 bars. Z06, GS, and Z51 fronts are the same with the Z51 being smaller on the rear vs the Z06 and GS. 31 front for the two Z's and GS. 28 rear for them except for the Z51 which is a 25.6. Don't know whether any other mag ride GS's have the ZR1 bars. Mine sure did.
peanut (09-20-2018)
Old 11-03-2018, 09:54 PM
Wegge1987
Cruising
Wegge1987's Avatar
I have a 2011 GS 6spd coupe it too has mag ride and ZR1 bars.
It also had a 3 bolt cam from factory which surprised me too.
To ZR1 /( FE5 ) Front Sway Bar part number ???
Quick Reply: ZR1 /( FE5 ) Front Sway Bar part number ???
