Going to a 100MM MAF from stock LS3/7 intake
Do I need a tune? The Callaway Honker ships with a 100 mm tube in which the stock LS3/7 maf card slides in - since the LS3/7 OEM intake has a tapered oval tract where the card inserts, im not sure if ill have issues with fueling...
The honker doesnt require a tune, as far as I understand it... (of course, more HP with a tune).
This is the throttle body, right? not the MAF housing?
bump for anyone interested. LTFT jumped about 10%. Def recommend a tune.
