"C6 from 2005-2010 navigation radio clock stops after battery disconnect
#41
Im still hoping its my Nav antenna although its a bear to install correctly. I also want to put a usb head in my 05. I've been assured it will work but am worried now. I still think I damaged my antenna while installing a PAL unit I got from Ray Kawal. He's never seen this problem either. Any Thoughts???
#42
Thats what I will do. I had a hard time getting it unplugged and was pulling hard on it. May have damaged it R & R the radio. I just want it fixed. Still want to know if its the Nav head or antenna? Is there any other possibility?
Ancient Warrior (08-10-2019)
#43
If you do try replacing the antenna, check the connector on the head unit and make sure you did not bend a pin. When you test it, make sure the car is outside where it gets a good GPS signal (GPS typically does not penetrate buildings well). It might take 10-20 minutes for the car to see enough satellites to develop a solution.
The following 3 users liked this post by 07MontyRed:
#44
I tried the antenna and no luck. It took a while to correct its location. No clock either. I hooked the old antenna back up. Had to recalibrate the location and it works but No Clock. Im stumped. The dealer will check for $150 Ouch.
#45
Okay, this is a real long-shot, but I saw this on another thread from a LONG time ago ... can't imagine it is the issue, but ...
"So the dealer replaced the radio and the clock worked for a little while then disappeared again. The only thing I did was put in a cd packed full of mp3's. The only thing I can figure is that an mp3 disk with lots of songs some how messes up the clock. If I remove the mp3 disk and cycle the power, the clock comes back. I need to try some mp3 disks with less data to see if the same thing happens but since this happened with two different nav radios I am guessing they all have the same issue. I'm surprised I haven't found anyone else who has run into the same problem."
So do any of the folks having the problem have MP3 discs in the unit? Not sure why it should matter, but ...
And I want to make sure that everybody is really getting a GPS signal (i.e., no slash through GPS on the nav screen). Just because the car displays a location does not mean it is receiving GPS (the cars essentially know where they are via inertial systems, although it is not terribly precise). Make sure there is no slash through the GPS icon (or that diagnostics reports a good GPS solution).
#46
St. Jude Donor '11-'12-'13, '15, '16-'17-'18-'19
when I turn mine on, the slash through the GPS is on for about a minute then the GPS and the slash disappear. I believe that is the normal function.
And I do not have CDs in my player. I have not owned or ripped CDs in many years.
#47
Best if someone contacts a GM district manager or local rep. and show them this thread.
06Rawpower (06-08-2019)
#48
Hmmm, that is sort of weird in my experience. My car is garaged (under a five-story concrete building), but it never displays a slashed GPS icon when I drive out. I wonder if the head unit has a battery (or capacitor) that normally retains the last GPS position (and time) ... perhaps the battery/capacitor is going bad with age (aggravated by power being removed from the car during service)? I have never looked inside the head unit so I don't know .... might be worth a call to one of the places that repair out-of-date nav systems (a quick Google search will bring up several) and if they have an idea.
tshirtmeister (12-26-2018)
#49
I was telling my wife I wonder if there is a battery too! We were just coming home from dinner and I thought maybe there's a battery for the clock inside the nav unit. There are firmware updates that are on DVD for a 2005 anyway and Im not talking about the Map DVD thats different. Im gonna take mine back out and look. My dash is still out so only six screws. I think it will still have to go back to the dealer for programming. Either that or sent off to be rebuilt. That will be $1400 dollars labor Mr Tshirtmeister. Thanks A lot Mr Goodwrench. LOL. I will post what I find. I will bet even if there is a watch battery in there it will still have to be reprogrammed at the dealer. That will be $150 Mr Tshirtmeister. Thanks Mr Goodwrench. LOL.
#50
Save your $150. My dealer's foreman did not know what's going on. Never heard of it. He said they do not have the capability to flash the radio for new software. All radio software update comes through disc updates. I have the latest disc, so there is that.
#52
he said if you can live without a clock everything esle is fine. Car only has 13,681 miles.
#53
You can find used radio/nav units with XM radio all over ebay for 3-400, but whats to say the problem want reoccur. Ive had 3 C6 vettes with nav and had the recalls done etc and even had one with a dead battery that set for a couple of days before i found out and put in new battery and it never had this issue, must be in the radio. did not even have to reprogram them either,just reindex the windows. one was a 2012 and one was a 2009. I know the radio is slightly different but not that much, nav is still the same. only my 06 has the problem.
#54
I just bought a 2006 Convertible and found it had 2 open recalls and took it in. When it came out GPS and Clock would not work. They took it back and said it was disconnected from battery too long and had to reprogram the car. That did nt help. Took it to a friend of mine who is a corvette mechanic and he reprogrammed it again and now GPS works but clock is still blank, as are the clock adjustment area. He said he has no idea unless it is in the radio itself. Said nav antenna was fine. Chevy dealer just did a crappy job in reprogramming
I am more and more a believer that this issue is satellite related, and where or what satellite the radio looks for to set the clock.
It's getting to be almost impossible for all these radios in these post to act the same way and for all units to have gone bad. As I said before, while my car was in the body shop about three weeks ago for a month and a half getting some mods put on it, the battery was connected and disconnected several times, and the clock synced every time after it was re-connected. This issue started after I disconnected the battery two weeks ago or so and has never come back.
Homebetter@aol.com (12-12-2019)
#55
Seems most likely that either something changed with the GPS time signal that created a problem for the C6 nav unit, or a time-based bug has been triggered in the C6 nav unit where it won't accept a GPS date/time of mid-Dec 2018 or later. Probably worked until the battery disconnect because once it gets GPS time once, it can track date/time internally afterwards?
#57
Really need some 2011-2013 testing here, so we know if upgrading to the newer 2011-2013 nav unit might fix this. Besides, if this problem affects those, a lot of those cars are probably even still under extended warranty. Seems like GM would need to do something.
Also: no MP3 disc in mine. I do have a PAL v2 connected.
The following 3 users liked this post by Fireblade:
#58
That's what I realised on my nav too, the last time. In the past, I could swear that the GPS fix was instantly avialable from engine start on. Now I have to drive a while til it comes to a fix. but the clock does not appear anymore.
#59
Just talked to radios and more. No battery inside. No the GPS clock signal from the satellites is OK. He did say he has seen the Nav disk cause this. For $450 the will refurb your radio with a 1 year warranty. AAAAAAAAAAAAHHHHHHHHHHHH.
#60
I called GM at 866-522-9559 . I urge everyone that has this problem to call this number and report the issue.
They referred me back to the dealer. Going at 9:30 in the morning. They said they will only charge me $55 and report back to GM the findings.
GM needs to know about this issue and the more people call and report it, the better.
I will keep you guys posted although I know that nothing will come out of this visit.
If the dealer cannot fix the problem , then I will report it to the BBB.
jhawk127 (03-25-2019)
