"C6 from 2005-2010 navigation radio clock stops after battery disconnect
#721
Cruising
I have the same problem. Just bought a 2006 Convertible. Disconnected battery in vain attempt to solve memory seat problem. I am not going to get bent out of shape over it. My Nav works fine and does not take a long time to acquire satellites as at least one other person has complained. I do wonder if the lack of the proper time will affect the accuracy of the GPS. I have not noticed it yet but I do not use the navigation very often. I will experiment.
For people who are bothered by it, my suggestion would be, as others have suggested, to get a 2011-2013 unit. I don't think that $500 is such a dear price -even adding the $150 to reprogram, given the improved GUI and additional capabilities. The least expensive aftermarket units I have seen from reputable manufacturers are around $700. Granted those are new and would support some advanced features, but the dealer would charge you well over $1,000 for a factory unit. My second option would be to actually buy an aftermarket unit, but then you have the nightmare of connecting the wiring (maybe Crutchfield has a kit that plugs into the factory connector)
I have just ordered V10 disk on e-bay ($20). I am looking forward to seeing what that buys me. I wanted mainly for updated POIs.
Personally I am more interested in getting the memory seats fixed (The seats work fine and the buttons make the right noises, but they do not cause the seats to actually move)
My C6 is my 4th Corvette and comes to me after a long hiatus. Happy to have a Corvette again.
#722
Well, my clock came back yesterday morning after being absent for weeks. I did nothing to initiate it. It had some trouble keeping the correct time throughout the day, so I had to reset it a couple of times. This morning everything seems fine and it is keeping the time correctly...for now!
#723
My C6 is my 4th Corvette and comes to me after a long hiatus. Happy to have a Corvette again.'
#724
I would like to share a thought that i had concerning the no clock situation.
In your HOME computer, if you have a problem, there is an option to reset the computer to an earlier date. This enables you to get all your computer settings back and have the system work as it did before you experienced whatever problem you had.
Is it possible to somehow use the same technique in the car computer? This would hopefully restore the Nav and clock to an earlier date, maybe in October or November of 2018, before we all experienced these problems. ANY IDEAS?
#728
Cruising
The exceedingly casual one's (TShirtMeister's) comments around the idea of replacing with newer C6 head is indeed interesting. And I am going to look into Bluestar. However, I am not keen to replace the console and steering wheel. To me the only real use of the usb is for TIDAL via Android Auto, and the AA interface to TIDAL sucks anyway. I think I'd rather just keep some CDs handy. I find the controls on the radio to be convenient enough that I don't need to have them on the steering wheel.
#729
I also have a 6 cd changer. Paid $60 for a new one on Ebay! Found 13 cd carts too for about $15 each. I'm stocked up! The Steering wheel wasn't that bad to install. Had to add wiring for the SW controls. You'll need a 2009 or later clock spring too. It does take some electrical know how. If anyone needs help I can point you to the info as its all here and been done before. Some folks were saying it wouldn't work on an 05 but I can say it does. I love it, I can switch cd in my changer with the 1-6 button.
The costar Blue star is awesome although in 05s it won't auto connect. I have to tap the blue Onstar button once and it connects. If you don't want to change the console you can just use a mini usb cable. It wasn't that bad but I was an ASE master mechanic and an Electronic Tech too. You can play usb devices such as iPods and Thumbdrives too. The Door speaker are a pain to swap. I instead added a Pyle 300W RMS Subwoofer that has a second 300W stereo amp and put 5.25" Kickers in the back and wired them to this amp. Its Bad ***, Loud and no distortion. The Subwoofer with second amp amp and speakers were less than $200. Sounds like a concert hall. Totally made the BLOZE system come alive. CDs sound way better than mp3 files. Although I have 800 cds on my 160gb iPod classic and it works great!
Heres the link for the stereo upgrade to a USB 20856087 stereo! 4 on Ebay for $500 - $750. Better hurry before they are gone. I got one for $350
http://www.kawal.net/USB%20Nav.htm
Heres a link to my upgrades! Hope it may help!
https://www.corvetteforum.com/forums...l-upgrade.html
#731
Replaced battery in our '08 today and add me to the list of no more clock. Called 800-222-1020 and got not-so-informed service rep who transferred me to a different customer service center, who had no idea what the info center on a corvette looks like, but finally agreed to open a ticket, of which he gave me the number, but no assurance that I'd be notified of any future fix. Wanted to set me up with dealership, which is where he said bulletins originate. I told him I'd seen enough posts about running diagnostics which don't show anything except a lighter wallet. Seems like someone at GM should have the clout to launch a fix.
#732
I wrote to BOSE via the website - this is an issue so many people are having - I also call GM and they gave me 100 dollars off my next service.
And for 9 dollars I bought a clock the clips to my A/C vent.
Write these people and tell them
https://automotive.bose.com/contact-us
#733
#734
You got the 10-bit vs 13-bit stuff backwards. 13-bit is the newer way. Also, there shouldn't be any reason they would need to move over to the 13-bit week field, 10-bit still works just fine as long as it's handled properly. Not to mention, if 10-bit week numbers was really the issue here, these units would have failed on April 6th, not last December. Frankly, we don't even know if the unit is using 10-bit or 13-bit weeks anyway.
To top it off, we don't necessarily even need GPS clocks here. Most people would be perfectly fine if the nav unit let them set the clock manually. The user interface to do so is there, but it doesn't actually work. Fixing that would be the easy way to "fix" this.
#735
Cruising
For those saying Denso must have known about the problem because they updated for 2011, and others saying that maybe the 2011+ cars are going to end up with this issue in the future:
The GPS specifications were updated in 2008 to deal with the 2019 epoch. Specifically, units had to be able to roll over to the new week count without reverting back to 1999. 2010 is roughly when all these changes would have been implemented. So Denso did know, and it will never be an issue with your 2011+ radio. It's possible Denso updated earlier than that, but GM was still buying an old part until they did a refresh to add the USB and other features.
It should be possible to fix this software-wise by just updating what the week 0 date is for the epoch, but that would result in this same issue occurring near the end of 2038 (I doubt anyone here is going to care too much about their GPS clock in a 28-33 year old car though). Alternatively, since there is a manual setting function that's simply locked out, they could unlock it.
GM may be running into an issue that Denso just doesn't want to do it (since there hasn't been a fix for any of the other manufacturers using their units yet either) because there's no money in it for them and they'll still be selling GPS units regardless of what car customers complain about, because they're not the OEM with the reputation to try and uphold.
So, short answer: if you can do the USB-unit upgrade, go for it. You won't have this problem in the future.
I'm still holding out for a software update because I literally just replaced mine 9 months ago because of a cracked screen, and it's not like I can make my money back by selling this one now.
tshirtmeister (04-19-2019)
#736
Even if you do assume that rollover was the problem, despite the lack of evidence, there's no guarantee that the 2011-2013 units would continue working after the next rollover in November 2038.
#737
The maker is Denso, and the nav unit in 2011-2013 Corvettes, which is also made by Denso, still works just fine. And by the way, GPS still works in the 2005-2010 units too, it's just the clock that doesn't.
#738
For those who want to keep up with the most current information, suggest following the only sticky thread in C6 Tech/Performance.
And follow my thread in Ask Tadge. There be advised that the moderator has stated he will refer no C6 questions to Tadge.
Do call Chevrolet Infotainment, give them your VIN and e-mail address, and get a Service Request Number.
Do backfill your local Chevy dealer with this Service Request Number.
Do NOT waste your money on a replacement head unit.
Do NOT waste anybody's time with BBB compaints and such.
Unless there's a secret screen spot we can press to fix this problem that nobody knows about, the ONLY fix is for GM and DENSO to reopen their support contract. DENSO owns the proprietary code that runs in our head units. They must update it and send out another round of DVDs. They may cost $$. But any other action is useless and will poison our relationship with GM, such as it is.
Finally, we're not alone. This is a Y2K-like problem that is starting to mushroom. A WiFi interconnect system installed in NYC after 9/11 failed on April 6. Both NYC and Northrup-Grumman have publicly denied there is a problem, but behind the scenes they're struggling mightily to find a solution. The NYCWiN system, which allows NYPD, FDNY, and many other city organizations to communicate with each other, is hard down. Apparently both neglected to read and act on the GPS update bulletin that announced the change of the epoch week field from 10 bits to 13 bits.
#739
I am wondering if there is a way to get into the car's computer. In your home computer, if you have a problem, you can reset it to an earlier date and then recover all your settings and resolve whatever problem you are having because you went to a date before the problem occurred. What if we could do the same thing with the car?
Also one of the posts on this Forum tells of a person, who after weeks of no clock, suddenly had the clock again. It came back. I did some research on this and was told that the total recycle of the cars' systems does not take effect until after approximately 50 restarts. So in theory after you lose your clock. if you continue to drive your Vette, your clock should come back after you start the car around 50 times. DON'T KNOW IF IT IS TRUE but was told by a Chevy mechanic. Hope he is right.
#740
I still wonder what chevy dealers are going to do with trades? Uhm we will have to take $3K off blue book cause ya clock no wookey! I got a 08 Vette you might like only problem is the clock don't work Sir! We''ll take $100 of the price!
