Corvette Camaro Tuner in Tampa
Former Vendor
St. Jude Donor '12
Check out my website -->> www.TampaTuning.com
Tampa Tuning is the home for street performance tuning starting at $325 Corvettes and Camaros at the stock to bolt ons level. My street tuning process takes several hours to complete. Its the best way to collect scanner data for low end drivability, cruising, and WOT under actual load and airflow of the vehicle.
My HP Tuners interface has unlimited credits for LS1, LS2, LS3, LS6, LS7, LSA, LS9, L99 engines
C7, Gen6 Camaros, and trucks are $100 more.
Great modification for the buck!
Instagram : TampaTuning
OUR TOTAL STREET PERFORMANCE TUNING PACKAGE FOR GM LS1-7 VEHICLES IS $325.00 WITH TRANSMISSION PACKAGE INCLUDES: www.TampaTuning.com
Read and reprogram your PCMs settings and perform real time scanning diagnostics for the best results
Increase power enrichment rate mode
Examine and change timing tables for additional horsepower & torque gain
Optimize your vehicles Air and Fuel Ratio monitored by the NGK/ AFX wideband unit
Reduction of intake air temperature table (heat soak)
Desired rev limiter adjustments
Park, neutral, and in- gear idle adjustments with and without A/C active
Adjust power enrichment delay to immediate
Engine torque management system reduced
Transmission torque management system reduced
Transmission shift points enhanced
Transmission shift times reduced
Transmission shift pressure firmness enhanced if needed
Skip shift deleted (CAGs 1st to 4th )
Fuel injector rescaling for aftermarket injectors if needed
Cooling fan activation temperature and percentage of cooling recalculated
Perform speedometer re-calibration for rear gear ratio and tire size change
Turn off check engine light and remove trouble codes
www.TampaTuning.com
Phil
www.TampaTuning.com
Phil
GRCTampa (01-08-2019)
Former Vendor
St. Jude Donor '12
Corvette Camaro tuner in Tampa E85
weekend bump
Tuning@TampaTuning.com
www.TampaTuning.com
Phil
www.TampaTuning.com
Phil
Former Vendor
St. Jude Donor '12
Florida racing weather is upon us. If you want to go faster, reach out for www.TampaTuning.com
www.TampaTuning.com
Phil
www.TampaTuning.com
Phil
