2011 Grand Sport Clutch Problem
Old 02-11-2019, 08:19 AM
Ballypinball
Ballypinball's Avatar
Default 2011 Grand Sport Clutch Problem
First the rod pulled out of the master cylinder piston
after fixing that, now the master cylinder un twists itself and pushes through the firewall
anyone got a fix for that
Old 02-13-2019, 12:15 PM
Fly N Low
Support Corvetteforum!
Fly N Low's Avatar
If the reservoir for the clutch fluid is white then you have the old master cylinder if it is black then that's the new cylinder. Sooooo if you have the old one order the new one and install it either way you will need to remove left front wheel, inner fender well liner, and windshield washer bottle and replace the cylinder in the firewall. Myself, I would not do all that without replacing the clutch master cylinder no matter which one I had. The hardest part of the job is getting the hydraulic line quick disconnect back together.
Old 02-14-2019, 03:38 AM
Ballypinball
mine is on the right side as its right hand drive
yes the cap fell off internal, removed and cleaned and fitted a O ring to stop it coming off again and fitted dot 4 fluid
then it unscrewed from the bracket so fitted some metal clips to stop it unlocking
it works at present but it is the white reservoir
I will order the new replacement and fit regardless as I no longer trust the one I have
Old 02-14-2019, 01:36 PM
truth.b
truth.b's Avatar
Right hand drive? Can you post pics of the car and the location of the components? I was unaware that there are any c6 Grandsport right hand drive vehicles.
Old 02-15-2019, 03:51 AM
Ballypinball
https://www.corvetteforum.com/forums...ished-rhd.html
Old 02-16-2019, 05:42 PM
Dano523
Dano523's Avatar
Received 3,019 Likes on 2,175 Posts
GM TSB-#14717--PIP-5037
https://gm.oemdtc.com/4335/clutch-ac...rolet-corvette
Hence if car is less than 10 years old, and has the master cylinder problem, Gm will replace the master cylinder in the car for free with a new upgraded master cylinder.
On the older clutch masters, the end plunger would pop off to cause a dead pedal, and the new master solves this problem.
Attachment 48341326
https://www.corvetteforum.com/forums...-pressure.html
Old 02-16-2019, 05:50 PM
Oldguychuck
Oldguychuck's Avatar
When did GM change to installing new upgraded master cylinder?
Old 02-17-2019, 05:14 AM
Ballypinball
as my car is in Australia doubt there is any warranty
I just ordered the part $110 cheaper than the $1100 tow bill last time
Old 02-17-2019, 11:39 PM
hawkgfr
hawkgfr's Avatar
Received 1,213 Likes on 825 Posts
Don't sell yourself short...you have GM dealers down under? If yes there are two extended warranties on the clutch master cylinder that run into late into 2021 and up to 120k miles.
At least check it out...
Old 02-18-2019, 05:09 AM
Ballypinball
We have holden dealers owned by gm
They don't even have the parts to fix no access to gm part numbers
Old 02-18-2019, 07:27 AM
Oldguychuck
Does anyone know what year vehicle the new model went on from the factory OR is it in the entire C6 run from 2005-2013?
To 2011 Grand Sport Clutch Problem
Quick Reply: 2011 Grand Sport Clutch Problem
