2008 C-6 oil pan wiring
I would appreciate some advice regarding my C-6 A6 base coupe (with Z51 package): During some routine maintenance, I noticed a wire leading into the block just above the oil pan that was resting on the exhaust. The wiring appears to be scorched on the surface only, and since I'm not getting any codes I hope I can locate something similar to the OEM heat resistant insulation and wrap the wire. I have researched and cannot determine what this sensor is. Also, recommendations on heat resistant tape or similar would be appreciated.
The wiring in question is the one leading into the orange colored section. The scorching can be seen to the left.
Supporting Vendor
I would appreciate some advice regarding my C-6 A6 base coupe (with Z51 package): During some routine maintenance, I noticed a wire leading into the oil pan that was resting on the exhaust. The wiring appears to be scorched on the surface only, and since I'm not getting any codes I hope I can locate something similar to the OEM heat resistant insulation and wrap the wire. I have researched and cannot determine what this sensor is. Also, recommendations on heat resistant tape or similar would be appreciated.
The following 2 users liked this post by subfloor@centurytrans:
Euthymicone (03-03-2019),
mikeCsix (03-04-2019)
Supporting Vendor
I'd recommend double checking to make sure it's not burned all the way through because if it is, it's unlikely that it'd ever cause a CEL which means you'd be driving around minus one knock sensor and be none the wiser.
You can also pull back the cover on the sensor, loosen the bolt and rotate the sensor to give more clearance tot the cat then retorque the bolt and re install the cover over the sensor.
Euthymicone (03-04-2019)
Good tip. Thanks. I'll be tackling that today and will try it. This is my second Corvette (the other was new and required minimal work) and there is quite a learning curve since I previously owned German and British sports cars. I imagine questions like this are simplistic to some, and not worth responding to. (I posted on another forum and with 51 views have not received any response.) Like I said, there is a learning curve and unfortunately, it is early in my learning process. We are all experts or at least quite knowledgeable in something, for me this ain't it. Again--appreciate the replies!
