c6 z06 clutch will not disengage
update i replaced master, has already new slave luk bought a pressure bleeder pressured it up to 15 psi from master res pushing fluid to slave did like 10 times pumped like 200 times, when i push clutch down i do hear clutch moving like a cm squeaky noise but not enough to release clutch, i cant really turn tires by hand when i do couple inchs engine turns as well,its feels like i need little more pedal to get it, however i did notice that when i put input shaft at first that pp fingers were not even 100% 3 or 4 were higher lower dont know if that may cause it thanks
