Z06 Front spring upgrade on a GS ?
Old 06-07-2019, 11:34 AM
Monks
CF Senior Member
Default Z06 Front spring upgrade on a GS ?
The front spring on my GS seems soft and many have said it is soft for autocross or HPDE.
Hyperco spring upgrades are $550, so I looked at the Z06 front spring, as I was told the Z06 is much stiffer ride
and would be a nice upgrade. I also have a friend with a very cheap one
Looking at the C6 front spring rates, the GS has a Z51 spring rated at 526 lbs., and the Z06 is rated at 531 lbs.
This doesn't make sense, Why would GM make two springs with different part numbers that are almost identical spring rate ?
Can anyone confirm that a Z06 front spring would be a good upgrade, even though the specs only show a 5 lbs difference in spring rate?
Thanks!
Monks is offline
Old 06-07-2019, 06:24 PM
sallen619
CF Senior Member
sallen619's Avatar
531 lbs - 426 lbs = 105lbs
Is the 426 lbs a typo?
Check the ZR1 spring rate. I'm assuming it is higher due to the weight of the supercharger...
sallen619 is offline
Old 06-07-2019, 07:26 PM
Turbo6TA
CF Senior Member
Turbo6TA's Avatar
The GS and Z51 use the same front spring ... I understand this spring is rated at 526 Lb Rate
Turbo6TA is offline
Old 06-07-2019, 07:29 PM
Turbo6TA
CF Senior Member
Turbo6TA's Avatar
In fact, here is the parts that make up the GS / Z16 suspension and there source ...
Turbo6TA is offline
Old 06-07-2019, 07:35 PM
Mike's LS3
CF Senior Member
Mike's LS3's Avatar
GS/Z51 Z06
F 526 531
R 645 782
You beat me to it!
Mike's LS3 is offline
Old 06-07-2019, 09:39 PM
Monks
CF Senior Member
Yes, a typo, should have been 526 lbs GS spring 531 Z06 spring
Monks is offline
Old 06-09-2019, 11:34 AM
madmatt9471
CF Senior Member
Support Corvetteforum!
madmatt9471's Avatar
Location: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
Originally Posted by Mike's LS3 View Post
GS/Z51 Z06
F 526 531
R 645 782
You beat me to it!
Are you saying the Z06 has a 782 lb Rear Spring? I have seen so many varying numbers that I'm glad to see the 782!
If so do you have the part number off hand?
Thanks,Matt
madmatt9471 is offline
Old 06-09-2019, 03:26 PM
Mike's LS3
CF Senior Member
Mike's LS3's Avatar
Thanks,Matt
Yes, 782 is the rear spring rate listed for C6 Z06. GM lists 6 different rear spring part numbers. Spring rates vary with transmissions because of weight. However, the C6 Z06 came from the factory with only a manual transmission. So you can eliminate any spring described as soft ride and auto transmission. Since you have a GS, you can eliminate that spring part number from the list. West coast corvette list the 2006-2013 C6 Corvette Z06 rear spring as GM #15233392. So, I am putting my money on that part number for the Z06.
Post on the C6 Z06 forum and ask for the rear spring part # to confirm.
Old 06-10-2019, 12:01 AM
Monks
CF Senior Member
My original question was why would GM make a Z06 front spring that is only 5 lbs more than the Z51/GS front spring?
Some racers say the Z06 front feels much stiffer that the Z51/GS front spring. Maybe feels better because the Z06 is 100's of pounds lighter.
I am wondering if the Z06 front spring would be a nice cheap upgrade for a GS front spring?
Monks is offline
Old 06-10-2019, 04:29 AM
C5Natie
CF Senior Member
C5Natie's Avatar
Not worth the effort for such a small change in spring rate. You'll benefit from a larger sway bar and better shocks like the Bilstein's by DRM. The GS is the heaviest of the C6's and better dampening help it a lot.
C5Natie is offline
Old 06-10-2019, 08:50 AM
PCMusicGuy
CF Senior Member
What makes you believe the spring feels soft? Also, have you tried to confirm your front spring? I have evidence that shows, at least on a 2009, that the factory installed a non-Z51 front spring in a Z51 optioned car.
PCMusicGuy is offline
Old 06-10-2019, 10:47 AM
Monks
CF Senior Member
That is my plan. The guy I am buying shocks (likely Koni 3013's) and sway bar (35mm solid) from also recommended a stiffer front spring, a Hyperco HPT. He raced
a GS and thought the springs were way too soft on the front.
I must admit that I have not taken this car on the track yet, Just trying to get it ready. I plan to run it with shocks and sways, then decide from there on the front spring.
Monks is offline
Old 06-10-2019, 10:52 AM
Monks
CF Senior Member
My last car was a C5 with DRM coilovers and light springs, My GS feels soft compared to that. I have talked to a few
autocrossers and the ones that can change it in their class do, even on street tires.
I will confirm my spring on Wednesday, when my Quick Jack 5000 arrives from Costco ( $999 on sale til the 16th)
Monks is offline
Old 06-10-2019, 12:39 PM
Mike's LS3
CF Senior Member
Mike's LS3's Avatar
For the same reason GM made the base rear spring rate 12 lbs stiffer than the Z51 rear spring 657 lbs. vs 645 lbs. respectively. . GM engineers designed a suspension package that achieves a desired ride quality using a combination of components: Shock valving, Springs, Sway bars and tires all of which differ from base to GS/Z51 to Z06 to ZR1. For example: Just by changing the spring rate or sway bar diameter you can encounter too much or too little oversteer or understeer. Suspension components work together and by changing only one suspension component you may not be doing yourself any favors in handling and ride quality. GM changes spring rates, shock valving and sway bar thicknesses to fine tune a suspension for that particular package.
Old 06-14-2019, 02:23 PM
mikeCsix
CF Senior Member
mikeCsix's Avatar
I wish Hyperco would have stated the spring rates for HPT series, you may have to change both front and rear to try to stay close to a balanced suspension. As an aside, the GS did seem to have a softer suspension than even the Z-51 made previously, and the car seemed to float on the track, though it does corner flatter in stock trim due to the Z-06 sway bars most likely. Sudden oversteer did seem to come up as I had a couple of occasions had to recover while on track, once in the rain and once on a dry track. It was a little spookie. I've since upgraded to the JOC package, shocks and sways, but may have to do springs too just to get back to neutral steering.
mikeCsix is offline
Old 06-15-2019, 12:28 AM
Monks
CF Senior Member
A national champion racer recommends good shocks, big front bar, stock GS rear bar, and the Hyperco HPT spring in front. Has used this and said it works great.
I am looking to try a Z06 front spring, they are cheap to try.
Monks is offline
Quick Reply: Z06 Front spring upgrade on a GS ?
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
  • Ask a Question
Question Title:
Description:
