Let’s talk about clutch not releasing
So I installed a new mantic twin disk clutch with a new slave and brand oem master cylinder. I was recommended to get rid of my tick master and go with oem so I did.
Ive has the clutch in for around 3k miles and it’s done this since day 1. Some days the clutch will not fully release. It’s just barely dragging. Other days it works perfectly fine. I do have a speed bleeder on it and have bled 3 or 4 brake fluid bottles through it.
I did measure for the slave and it was right on the cusp of needing a shim and not needing a shim. I don’t have the measurements anymore. Also every single time I do a good pull and decelerate and push the clutch in I have to force it out of gear. That happens on every deceleration. Not real sure on where to start
