Whining in rear
Old Sep 21, 2019 | 10:25 PM
rbroom1967's Avatar
rbroom1967
Default Whining in rear
What is causingwhinning in rear? Can only hear it when windows up and radio off. It’s a 2007 corvette
Old Sep 22, 2019 | 02:06 AM
Moved to C6 Tech.
Old Sep 22, 2019 | 04:37 AM
LS YEET's Avatar
LS YEET
Is it a specific side, middle? Any aftermarket gearing?
Old Sep 23, 2019 | 07:35 PM
pyrodav's Avatar
pyrodav
Tires wearing evenly?
Old Sep 23, 2019 | 08:34 PM
rsb213's Avatar
rsb213
If it's a manual, and happens in a specific gear only, I have bad news for you
Old Sep 25, 2019 | 07:58 PM
rbroom1967's Avatar
rbroom1967
No after market gearing and sounds more profound on passenger side , but hear in middle also
Old Sep 26, 2019 | 09:33 AM
deriley's Avatar
deriley
Veteran: National Guard
Wheel bearing. Did both of mine now quit.
Old Sep 26, 2019 | 07:57 PM
rbroom1967's Avatar
rbroom1967
About how much was the cost or did you do it yourself
Old Sep 28, 2019 | 01:52 PM
deriley's Avatar
deriley
Did myself used detroit axle bearings under $40.00 each check Ebay.
Old Sep 28, 2019 | 08:00 PM
rbroom1967's Avatar
rbroom1967
Old Sep 29, 2019 | 11:17 AM
rbroom1967's Avatar
rbroom1967
Don’t have room or time to change myself. I’m looking for someone to do it without going to dealership. I know they will charge an arm and leg.
Old Oct 4, 2019 | 11:30 AM
sonnysucks's Avatar
sonnysucks
Wheel bearings you can usually turn in and out of, wait for the sound and steer right and left and see if it goes away, you turn into a bad bearing. Rear end will be more howling sound kinda, speed dependent or just overall at all speeds?
To Whining in rear
