First track pass since mods
Old Mar 16, 2023 | 07:40 PM
farmington's Avatar
farmington
Default First track pass since mods
2012 base. Got BTR stage 1V2, full exhaust with NPP and off-road mid, rod mod intake, drag radials (275-40-18 Nitto R555-2) and Yank ss3600 converter.
made 3 passes, only 1 didn’t blow tires off on the hit. Good pass was leaving on idle with 22 lbs in the drag radials. They only had 1/8 mile clocks working.
Ran 7.17 @102 with 1.72 60’ feel there’s a high ten at least in there. 7.17 is equivalent to 11.28 according to the web page I accessed. I’m happy but want more. Did average 29 mpg there and back (85 miles each way)
Old Mar 16, 2023 | 09:05 PM
old motorhead's Avatar
old motorhead
Quick and efficient. The way a Vette ought to be.
Old Mar 16, 2023 | 10:23 PM
thehulk's Avatar
thehulk
Ran 7.17 @102 with 1.72 60’ feel there’s a high ten at least in there. 7.17 is equivalent to 11.19 according to the web page I accessed. I’m happy but want more. Did average 29 mpg there and back (85 miles each way)
Man that MPH is pretty good. Definitely 10's
Old Mar 17, 2023 | 01:20 AM
HOXXOH's Avatar
HOXXOH
Looking good for the 1st time out.
Drop the pressure to 18#, do a solid 5 sec 2nd gear burnout and then launch around 1200-1500. Should hit 10's then.
Old Mar 17, 2023 | 08:16 AM
El_Steveo's Avatar
El_Steveo
I'm here for it. great 1/8 mile runs
Old Mar 17, 2023 | 12:14 PM
mcm95403's Avatar
mcm95403
Sweet! Shows it doesn't take a huge lumpy cam to go good!
Old Mar 18, 2023 | 07:09 PM
Omega Doom's Avatar
Omega Doom
congrats thats great 1st time results you should keep logging and trying different launch RPMs off idle then 2k then 2200 then 2500 but like HOXXOH said drop tire pressure first try 20psi then 18psi if you get stuck at 7.0 take out the passenger seat for that elusive 6.99999999999 lol
Old Mar 29, 2023 | 05:57 PM
camaro75racer's Avatar
camaro75racer
Nice times. What track were you at? I'm in the upstate and run Greer, Shadyside, Union, and Carolina occasionally.
Old Mar 29, 2023 | 09:20 PM
farmington's Avatar
farmington
It was at Darlington. They had a free day. Want to try Rockingham since it was just rebuilt. Wish North Myrtle Beach was open, it’s 5 minutes away.
Old Mar 30, 2023 | 12:13 PM
da6speed's Avatar
da6speed
I agree with HOXXOH on tire pressure and a solid burnout. Might try different launch techniques though. I know when I had a motor car with the yank ss3600, the more I stalled it up, the harder it left. It did not like being flashed. I went bottom 1.5s on the regular with just bolt-ons and 19" radials. Try it at 1500, then at 2000, then 2500, then 3000, etc. I think I could footbrake mine up to 3200 or so if my memory is right.
Old Mar 31, 2023 | 10:55 AM
HOXXOH's Avatar
HOXXOH
With my 3600 and 275 x 17 Hoosiers, my best 60's were had with about a 1400-1500 launch. After switching to a 4000, my best times were with a 1700-1800 launch in the high 1.4's. That was with just bolt-ons. So going to internal mods, you'd need to find your own sweet spot. Nothing is set in stone, so everyone has to experiment with what they have, the track conditions at the time, and their technique. Just because everything worked well in the morning time trials, doesn't mean the mid-afternoon conditions will produce the same results.
To First track pass since mods
