After several years, I am finally having headers & X-Pipe installed on my 06 C6 base coupe. The car has a current Dyno Tune, cold air intake, and NPP cat back already installed. With the header and X-pipe, the installer will do an HP street tune. With the extreme heat wave happening in the country, I am concerned about the extra under-hood heat associated with headers. Should I be concerned?
I had similar concerns when planning my header install, since I autocross in pretty hot weather sometimes. My tuner advised that coated headers weren't usually needed on C6's and I haven't had any problems with underhood temps with uncoated Kooks and catted X-pipe. I've 'hot lapped' the car over and over again at test and tune events in 90+ degree heat without any issues with oil, coolant, or trans temps.
I thought about ceramic coating the headers, but chose not to. The install is scheduled a few days from now.
I've had multiple electrical connectors start to melt and the steering shaft white grommet melt as well WITH ceramic coated headers. Yes, you should give it due concern. Wrap connectors close by and shield what you can if you aren't coating headers. Especially the starter.
My car was tuned during 96* ambient temps with my headers on. It still made the power it needed to make.
I only wrapped my 02 extensions, but no other heat shielding at all and not a single issue with my car. I do not feel any additional heat in the cabin than I did with stock headers with cats
Always insulate with coatings/wrap/shields. Insulation is performance, economy.
All factory vehicles have insulations, shields, heavy thick exhaust manifolds, insulating plastic manifolds/covers, etc...
It is always done for performance, economy, efficiency., which always increases with insulation, heat = energy.
all power plants in the world run the highest feasible temperature possible for best efficiency, including combustion engines for vehicles.
The average temperature of all engines in vehicles has been increasing every year.
Cheap header materials might crack or warp, sure. Cheap anything is you get what you pay for
But having a cheap junk on your car is not a reason to not do things correctly. All performance mindset = insulation, period.
Daily or weekend cruiser. I live in TX. Had LTs for 10 years and no issues. It's not a daily but when I do drive it, I usually leave it outside the garage for about an hour or 2 before pulling it in. Mainly to not heat up the garage too much.
