07 Z06 fuel issues.
Old May 25, 2026 | 08:35 PM
26mconnolly's Avatar
26mconnolly
Default 07 Z06 fuel issues.
Hi all, hope your well
I have an 07 Z06, car has a big fuel system (id1050x, dual fore walbro 525 hellcat pumps)
I was driving, put the car in neutral to coast to a stop, and the car slowly died on me. Would not start back up.
The fuel Schrader valve had no fuel coming out, the car has fuel. Put a new fuel pump relay, adjusted the pins below the relay and still nothing.
The fuel pump has probably 40-60k miles on it.
The fuel wire for the main wiring harness seems to be aftermarket.
I put power to the relay and nothing came out of the fuel line.
Is the only next option to drop the tank and see if the pump is getting power, or if it needs to be replaced.
Or is there a wire that does along the body of the car that could be causing this issue that I should check?
Old May 25, 2026 | 10:34 PM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
You need to TEST all 4 terminals of the relay...do you know how to check the load and control sides of the relay ??...all you need is a 12 volt test light...you also need to voltage drop the fuel pump circuit also.
Old May 26, 2026 | 07:27 AM
26mconnolly
I bypassed the relay and gave it 12 volts yesterday, still wouldn’t start
Old May 26, 2026 | 07:41 AM
C5 Diag's Avatar
C5 Diag
If you have high resistance in the circuit giving it 12 volts doesn't do anything for you...the pump is not getting the proper current....you need to check the positive and negative sides of the pump from the battery to the pump...since you pump is not working you have to substitute the pump with a headlight bulb or you won't be able to voltage drop the pump...if voltage drop is good and pump is inop you have a bad pump...I don't know if your pump has aftermarket wiring but X459 is where you need to check...you have 3 other terminals of the relay to test.
Old May 26, 2026 | 08:14 AM
26mconnolly
Old May 26, 2026 | 08:24 AM
C5 Diag's Avatar
C5 Diag
The 20 amp fuse is upstream of the relay so the fuse isn't your issue but still needs to be looked at...resistance causes heat and that is why your fuse is over heated...you need to look into the fusebox...are you 100% positive you fed the right terminal 12 volts ??...if you take a test light connected to B+ and probe terminal 87 (G7) the test light should illuminate as it will finds a ground through the windings of the fuel pump to ground !!
Old May 26, 2026 | 10:30 AM
C5 Diag's Avatar
C5 Diag
BTW, X184 is near the front passenger quarter panel and X420 is below the EVAP vent valve on the right rear frame rail.
Old May 26, 2026 | 10:31 AM
26mconnolly
it’s got 2 big fuel pumps so it has aftermarket wiring. It has its own ground, and it’s powered right to the alternator lol
Old May 26, 2026 | 10:33 AM
C5 Diag's Avatar
C5 Diag
Unfortunately you'll have to diagnose this yourself as I don't know how this is wired...maybe you can provide a diagram of the circuit !!...so instead of coming from B+ as in the schematic it is coming from the alternator B+ and still going through the 20 amp fuse and relay ??...how many amps do these pumps draw ???...my stock 08 pump draws a little over 8 amps...the more resistance you have in the circuit coupled with the increased current flow you have from these aftermarket pumps will lead to what you see with your fuse...the pump circuit is very easy to diagnose as long as you have a basic understanding of electricity...if you are more of a "wrench turner" than a diagnostician I'd seek out an auto electric shop in your area...if your voltage drop is negligible then you have bad pumps...without testing you are just guessing...you don't want to remove the pumps needlessly...I don't know if you or someone else did the pump installation....the last member with an inop pump had a burned terminal at X184.
Old May 27, 2026 | 08:09 PM
Mr.fork's Avatar
Mr.fork
There is a fuel pump controller between the relay and your fuel pumps. One pump should be on all the time, the other will only come on when a Hobbs switch tells it to activate assuming this is a boosted setup.
The controller is typically located in the passenger side rear cubby hole, behind the wheel well plastic, or under the carpet somewhere in the rear passenger side trunk and will look like the picture below. with power applied at the relay, you should see voltage applied at pump 1. If you are seeing voltage at remote 1, you should also see voltage at pump 1. If you see voltage at pump 1 and are still getting no fuel pressure, your primary pump is likely busted. If you are seeing no power at pump 1 when you have power to remote 1, the fuse is likely popped. You can try switching power between pump 1 and pump 2 as well to see if pump 2 comes on when remote 1 is activated.
To 07 Z06 fuel issues.
