If the aluminum frame comes....
Re: If the aluminum frame comes.... (SWCDuke)
All said, today's steels are still really darn cool materials. I hope that the coolness factor of Al or Al/Mg alloys don't overshadow the advances in steel engineering.
Re: If the aluminum frame comes.... (Matt Black)
I don't think the Z06 (or any derivation of the C6 series) will see an aluminum frame under it...they will still be based on the current structure and the weight reduction will come from other areas such as wheels, interior electronics (lackthereof), hardtop body style and carbon fiber hood maybe and the rest of the results will come from adding more power of course, IMO.
☠☣☢ Semper Ebrius ☢☣☠
One thing I didn't see mentioned, though I may have missed it, as that weight reductions in the frame move the center of gravity upward which is not good for handling.
The best places to take out weight, from a performance and ride perspective, are unsprung weight (of course) and from places that are high up and/or far forward. For example, the hood, windshield frame, windshield, engine, etc. The C5's carbon fiber hood only takes, what, 10 lbs or so? But it takes those 10 lbs. from one of the best places it could possibly be taken.
Re: If the aluminum frame comes.... (Scissors)
Ok, so I went and lifted the hood on my 99, (since I do not have a C6 in the driveway.)
The side rails measure about 6.75 in x 3.75 in the rain.
McLennans book says GM starts with a 6 in pipe with a 0.08 in wall. This works out to about 5 pounds per foot or about 180 pounds for 36 feet of side rail and adding in for the front and back pieces.
Reverse engineering - the final wall thickness works out to .071 inches after the rail is hydro-formed.
To match beam stiffness: using SWCs E values and densities of steel at 490 pcf and aluminum at 170 pcf. I come up that to keep the same outside dimensions of the rail; one would need to increase the wall thickness, 4 sides, to 0.232 inches. However, this increased rail weight to 5.5 plf. Trying variable wall thicknesses the best I came up with was 4.5 plf.
Net savings? 18 pounds on the frame by going to aluminum without changing outside dimensions.
What will GM do? Who knows?
George
[Modified by 999, 12:24 PM 2/3/2004]
George
Received 1,974 Likes
Re: If the aluminum frame comes.... (999)
Good analysis! It shows that the savings from aluminum is marginal at best unless the outside dimensions of the rails are increased, which would essentially be a complete redesign of the chassis.
It also shows why aluminum structure cars like the F360 and NSX are within about 3 percent of the current Z06 curb weight.
Duke
Duke
1 Post
Cruise-In I Veteran
Cruise-In II Veteran
leaving out the a/c,radio,sound deadener,power windows,ETC will reduce the weight more than any change in material in the C-6. that is why the FRC is the performance model because it weights 80# less up high over the hatch back coupe. :chevy
Another good point! The more you compare the C6 chassis and engine with
so-called industry benchmarks, including all the near exotic and exotic cars,
the more you realize that the GM guys are wizzards to make the Corvette as light and powerful as it is (not to even mention low operating cost - fuel, insurance, and maintenance) at such a LOW price point!!!
Duke
Duke
