Pfadt Complete Header Package/ w Airaid Intake System
Former Vendor
St. Jude Donor '13
06-13 Corvette ZO6 Complete Header, X-Pipe, Gasket, O2 Sensor Extender Package with Cats w/Airaid Intake System
Pfadt Power Products now brings you a race-proven Tri-Y header design making more HP and Torque at an affordable price!
1.75/2" tube diameter
CNC flanges with OEM locating features
Fully hand-TIG welded on-site
T-304 16 Gauge Stainless Steel
Fully Brushed Stainless Steel Finish
V-Band Clamp connections
Equal length long tubes
1-piece X-Pipe available with high flow metal matrix Catalytic Converters
Full 3" collector and X-pipe
Comes with bullet-nosed flange bolts for installation
Comes with O2 Sensor extenders below
Comes with Cometic Multi-Layer Steel gasket upgrades below
Exhaust system with Cats is 24lbs lighter than factory
Exhaust system without Cats is 27lbs lighter than factory.
Made in Salt Lake City, Utah
The Pfadt design takes proper exhaust flow to a new level by pairing non-adjacent cylinders together to create a super-scavenging effect with the 4-into-2-into-1 (Tri-Y) construction. In this system, the exhaust flow from individual cylinder pulses are optimized to suck air into the combustion chamber from the intake. This creates a much more efficient power curve that results in a greater amount of usable torque (called torque under the curve) in the mid-range, while not sacrificing any top-end power for peak numbers.
AIRAID Cool Air Dam Intake System; Incl. Modular Intake Tube;
It is a proven scientific fact that cold air is denser than hot air, which means that an engine breathing cold air is going to make more power than the identical engine breathing hot air. The quest for cold air is what drives the AIRAID® Cold Air Dam Intakes. The CAD Intakes retain the stock filter location but give the stock intake system a big boost with the addition of a huge air inlet that provides a steady, free-flowing supply of cold air. This is done via Cold Air Dam panels, which mount in the factory air box location and utilize any factory cold air inlet ducts that are present, while adding additional cold air passages to the filter. These panels also keep the filter isolated from the hot engine compartment air by sealing to the underside of the hood via blade-style weatherstripping. Each AIRAID® Cold Air Dam Intake is designed specifically for each vehicle application and offers a simple, trouble-free installation using simple hand tools. Like the rest of the AIRAID® systems, the CAD Intakes are Made in the USA and include all the necessary installation hardware as well as easy-to-understand instructions written with the do-it-yourselfer in mind.
$2095.99
Delivered Lower US
ZO6
http://www.xplosiveperformance.com/06-13-Corvette-ZO6-Complete-Header-X-Pipe-Gasket-O2-Sensor-Extender-Package-with-Cats-wAiraid-Intake-System_p_3594.html#
C6
http://www.xplosiveperformance.com/06-13-Corvette-C6-Complete-Header-X-Pipe-Gasket-O2-Sensor-Extender-Package-with-Cats-wAiraid-Intake-System-_p_3595.html
Follow us on Facebook
Toll Free 888.493.8041
PM
Former Vendor
St. Jude Donor '13
$2095.99
Delivered Lower US
ZO6
C6
PM
