** Corvette C6 Rear Resistor Harness ***
Former Vendor
[size="5"]Hi everyone,
We're back on the forums and are celebrating with a sale on our C6 Rear Resistor Pack![/size]
Does your C6 Corvette have hyper flash / hyperflash after changing the taillights to LEDs?
Get one of these resistor harnesses from us that plugs into an existing harness and mounts to an existing bolt on your C6 and solve those issues in as low as 20 minutes!
Assembled with parts consisting of connectors, TPA's and terminals to ensure the best fit with your original harness, the C6 Rear Resistor Harness will fix your hyperflashing of your taillights.
This harness uses TPA (Terminal Position Assurance) equipped connectors just like the original connectors to ensure that each terminal has a "locked in", assured connection. The TPAs can only be inserted if each terminal is completely seated in the connector housing. This will make sure that the terminals will not back out of the housing due to natural vibrations.
As a forum members, you can use code C6RR10 at checkout for $10 off
Order Here $65-$10= $55 Shipped
* CA Customers pay sales tax
- Solves hyper flashing / rapid flashing caused by LED Taillights without splicing in load resistors yourself
- Simple 20-30 minute Plug N Play installation with the included instructions with pictures.
- Includes ferrite bead to help further minimize interference
- 30 Day Moneyback Guarantee!
Last edited by CorvetteEnvy.com; 06-25-2018 at 09:51 PM. Reason: fixed dollar amount
