[Z06] Jack question
Jack question
I am assuming that most of you guy's are jacking up the front of your new C6Z's the same way we used to jack up your C5Z.
2x6x25" piece of wood between the A-arms and placed under the cross member with a floor jack to do the work and then two jack stands, one at each end if the wood piece.
Same for the rear end.
I stick a jack under the rear end from the rear of the car and jack it up putting jack stands under the frame on each side. Then I go to one side of the car and jack it under the front cross member high enough to put a jack stand under the front frame on each side. Or, I use a lift! The lift is the easy way but everyone does not have ready access to one.
They look like a hocky puck and have a T bolt that locks into frame rail.
