[Z06] ZR1/SS/BD frame-steel or aluminum?
Just now reading a question of how to fix a bent Z06 frame. The concensus so far was that these don't fix very well. I've also read of difficulty of attaching roll bars and other hardware due to the frame being aluminum and difficult to weld. It's my understanding that the Z06 frame , being made of aluminum, has a wall thickness a big greater than the steel of the base car. Not wishing to hijack the thread about repair of a bent Z06 frame I've started this conversation about speculation regarding the ZR1 frame.
Will it be steel or aluminum? The aluminum Z06 frame has the primary purpose of reducing weight to offset the increased weight of the LS7. Is the aluminum superior to steel for some other reason(s) or is it , in fact, inferior to steel in all respects except weight?
So with a presumed hp of 650 in the supervette will they use steel or aluminum? My bet is that they will use steel due to higher strength. What do you think? Also, open for discussion would be guesses/educated or not regarding other differences the ZR1 may have with the Z06 and base car. It will be really interesting to finally learn what's in the new beast.
I was just assuming aluminum, as that was the frame for the highest performing car they had which is the Z. If they go back to steel for the new one, it would seem like it kind of puts the ZO6 as as oddity leaving people wondering why they went with the aluminum frame in the first place. I would say they will use it.
Received 3,802 Likes
"Ask Tadge" Producer
The frame for the SS will almost certainly be Al, with the goal to reduce mass as much as possible. I'd take that one to the bank.
jas
It will be the same as the Z06. GM could care less how hard it is to put a roll cage in the car.
Also with the goal of going lighter then the Z06, it would be nearly impossible to accomplish this by adding a heaver frame along with (I'd assume) even heavier breaks and the addition of a supercharger.
There should be an option to select steel frame and just eat the extra weight. I'd get it!
