[Z06] 07 ZO6 Oil Leak
07 ZO6 Oil Leak
I know some of you all will scold me for telling this but I have had my Z in Strage since December and I backed it out of the garage the other day and noticed a pool of oil on the floor. I was shocked since this car only has 4500 miles on it. I have not had a change to look underneath to see where it might be coming from. But my first guess would be rear main seal. I let it run the other day and it isn't leaking on anything that could burn it off either. Now I let it sit in my driveway and it didn;t leak a drop after letting run for 20 minutes. She doesn't come out of storage until Memorial day weekend but I am thinking I may need to trailer her to the dealership to be looked at.
Has anyone experienced this?
This really bothers me! I have a 03 GMC HD and it has 95K on it and does't leak a drop.
Any feedback would be apreciated!
GS011 (05-26-2023)
I think it would make more sense for you to find the leak before guessing where it may be, at least get the general area. You could have clipped a hose going to the dry sump, could be a loose filter or drain plug backing out, and yes it could be a rear main seal leak, could be a valve cover leak and it could be none of those. A lift should tell you in a matter of minutes.
Rear End Leak
I have a 2008 Z06, purchased in 11/28/07. I found some oil drops in the back. Placed a card board and found drops once in awhile. Placed the car on ramps and found the rear leaf oily. Wipe the oil off and once after several rides oil would again puddle up on the leaf and drop to the floor. Don't know if this is a seal problem. Had a similar problem with a 1999 coupe, automatic.
Here is a TSB I listed for the LS2 folks, but it applies to many of the GM engines.
Subject: 5.3L LC9, LS4, L33, LH6, LM4, 5.7L LS1, LS6, 6.0L LS2, L76, 6.2L L92, 7.0L LS7 - Engine Oil Leak at Rear Cover Assembly Area (Engine Block Porosity RTV Repair Procedure) #05-06-01-034E - (02/12/2007)
Models: 2004-2007 Buick Rainier
2005-2007 Cadillac CTS-V
2007 Cadillac Escalade, Escalade ESV, Escalade EXT
2003-2007 Chevrolet Corvette, TrailBlazer
2004-2006 Chevrolet SSR
2005-2007 Chevrolet Silverado, Silverado SS
2006-2007 Chevrolet Impala SS, Monte Carlo SS, TrailBlazer SS
2007 Chevrolet Avalanche, Suburban, Tahoe
2003-2007 GMC Envoy, Sierra
2004-2005 GMC Envoy XUV
2007 GMC Yukon XL, Yukon Denali, Yukon XL Denali
2004-2006 Pontiac GTO
2005-2007 Pontiac Grand Prix GXP
2005-2007 Saab 9-7X
with 5.3L, 5.7L, 6.0L, 6.2L, 7.0L VORTEC™ GEN III or GEN IV V8 Engine (RPOs LC9, LS4, L33, LH6, LM4, LS1, LS6, LS2, L76, L92, LS7)
This bulletin is being revised to update warranty information. Please discard Corporate Bulletin Number 05-06-01-034D (Section 06 -- Engine/Propulsion System).
Condition
Some customers may comment on an engine oil leak.
Cause
Upon initial diagnosis, it may be determined that the leak is coming from the rear cover gasket. This condition may be caused by engine block porosity on the sealing surface. This issue pertains to aluminum block applications only.
Correction
Follow the steps for Oil Leak Diagnosis in SI to determine the source of the leak. If the leak has been diagnosed as coming from the engine rear cover assembly, refer to Engine Rear Cover Replacement in SI and remove the engine rear cover assembly. Inspect for engine block porosity where the engine rear cover mates to the engine block. If porosity is found anywhere on the sealing surface, use the following procedure to apply RTV to repair the engine block porosity. Refer to the illustration below.
Important: Clean any residual oil from the block and cover before applying the sealant in the next step.
Wipe a small amount of RTV, P/N 12378521 (in Canada, use P/N 88901148), onto the surface using a plastic scraper to fill the porosity.
Remove any excess RTV material, especially from inside the high pressure oil passage. Refer to #1 in the above illustration.
The joint may be closed immediately after applying the RTV. Total joint time after the RTV has been applied must be under 20 minutes.
Important: Refer to Engine Rear Cover Replacement in SI and follow the tightening specifications and sequence.
Reinstall the engine rear cover using a new gasket and a new crankshaft rear main seal. Refer to Engine Rear Cover Replacement in SI.
Parts Information
Important: For Saab (U.S.) only, use P/N 12345795, Engine Oil Dye (U.S.), or equivalent.
Part Number
Description
Qty
12574293
Gasket - Crankshaft Rear Oil Seal Housing
1
89060436
Seal, Crankshaft Rear Main
1
12378521 (U.S.)
88901148 (Canada)
Sealant
1
12345795 (U.S.)
Dye, Engine Oil
1
10953470 (Canada)
Dye, Engine Oil
1
Warranty Information
Excluding Saab U.S. Models
For vehicles repaired under warranty, use:
Labor Operation
Description
Labor Time
J7510*
Oil Leak -- Rear Cover Area -- Porosity Repair
CTS-V
5.5 hrs
Corvette
- M/T
- A/T
5.9 hrs
5.4 hrs
SSR
5.4 hrs
TrailBlazer/Envoy/Rainier/Saab 9-7X (Canada)
- 2WD
- 4WD
5.7 hrs
6.5 hrs
GTO
- M/T
- A/T
10.2 hrs
10.5 hrs
Grand Prix/Impala/Monte Carlo
5.7 hrs
Silverado//Sierra Models
- M/T
- A/T
4.5 hrs
5.5 hrs
Avalanche, Escalade, Suburban, Tahoe, Yukon Models
4.5 hrs
Add
With skid plate
0.2 hr
With HP2**
0.5 hr
To clean parts over 48,000 km (30,000 mi)
0.1-0.3 hr
* This labor operation is for bulletin use only. It will not be published in the Labor Time Guide.
** HP2 Hybrid Propulsion Electric, AHS2
Saab U.S. Models
Labor Operation
Description
Failed Object
Fault/Reason Code
Location Code
Warranty Type
Repair/Action Code
Labor Time
2161901
Replace part, Seal, End Plate V8 T-Truck
21619
57
0
01
01
6.5 hrs
Add
9821001
R&R Anti-Submarine (Skid) Plate
0.2 hr
Add
0.1 to 0.3 hr in 99 time
GM bulletins are intended for use by professional technicians, NOT a "do-it-yourselfer". They are written to inform these technicians of conditions that may occur on some vehicles, or to provide information that could assist in the proper service of a vehicle. Properly trained technicians have the equipment, tools, safety instructions, and know-how to do a job properly and safely. If a condition is described, DO NOT assume that the bulletin applies to your vehicle, or that your vehicle will have that condition. See your GM dealer for information on whether your vehicle may benefit from the information.
WE SUPPORT VOLUNTARY TECHNICIAN CERTIFICATION
© Copyright General Motors Corporation. All Rights Reserved.
2005-2007 Saab 9-7X
Condition
Cause
Correction
Parts Information
Part Number
Description
Qty
12574293
1
89060436
1
12378521 (U.S.)
88901148 (Canada)
Sealant
1
12345795 (U.S.)
Dye, Engine Oil
1
10953470 (Canada)
Dye, Engine Oil
1
Labor Operation
Description
Labor Time
J7510*
CTS-V
5.5 hrs
Corvette
- M/T
- A/T
5.9 hrs
5.4 hrs
SSR
5.4 hrs
- 2WD
- 4WD
5.7 hrs
6.5 hrs
GTO
- M/T
- A/T
10.2 hrs
10.5 hrs
5.7 hrs
- M/T
- A/T
4.5 hrs
5.5 hrs
4.5 hrs
Add
With skid plate
0.2 hr
With HP2**
0.5 hr
0.1-0.3 hr
Saab U.S. Models
Labor Operation
Description
Failed Object
Fault/Reason Code
Location Code
Warranty Type
Repair/Action Code
Labor Time
2161901
21619
57
0
01
01
6.5 hrs
Add
9821001
0.2 hr
Add
My 2005 C6 LS2
2005-2007 Saab 9-7X
Condition
Cause
Correction
Parts Information
Part Number
Description
Qty
12574293
1
89060436
1
12378521 (U.S.)
88901148 (Canada)
Sealant
1
12345795 (U.S.)
Dye, Engine Oil
1
10953470 (Canada)
Dye, Engine Oil
1
Labor Operation
Description
Labor Time
J7510*
CTS-V
5.5 hrs
Corvette
- M/T
- A/T
5.9 hrs
5.4 hrs
SSR
5.4 hrs
- 2WD
- 4WD
5.7 hrs
6.5 hrs
GTO
- M/T
- A/T
10.2 hrs
10.5 hrs
5.7 hrs
- M/T
- A/T
4.5 hrs
5.5 hrs
4.5 hrs
Add
With skid plate
0.2 hr
With HP2**
0.5 hr
0.1-0.3 hr
Saab U.S. Models
Labor Operation
Description
Failed Object
Fault/Reason Code
Location Code
Warranty Type
Repair/Action Code
Labor Time
2161901
21619
57
0
01
01
6.5 hrs
Add
9821001
0.2 hr
Add
2005-2007 Saab 9-7X
Condition
Cause
Correction
Parts Information
Part Number
Description
Qty
12574293
1
89060436
1
12378521 (U.S.)
88901148 (Canada)
Sealant
1
12345795 (U.S.)
Dye, Engine Oil
1
10953470 (Canada)
Dye, Engine Oil
1
Labor Operation
Description
Labor Time
J7510*
CTS-V
5.5 hrs
Corvette
- M/T
- A/T
5.9 hrs
5.4 hrs
SSR
5.4 hrs
- 2WD
- 4WD
5.7 hrs
6.5 hrs
GTO
- M/T
- A/T
10.2 hrs
10.5 hrs
5.7 hrs
- M/T
- A/T
4.5 hrs
5.5 hrs
4.5 hrs
Add
With skid plate
0.2 hr
With HP2**
0.5 hr
0.1-0.3 hr
Saab U.S. Models
Labor Operation
Description
Failed Object
Fault/Reason Code
Location Code
Warranty Type
Repair/Action Code
Labor Time
2161901
21619
57
0
01
01
6.5 hrs
Add
9821001
0.2 hr
Add
I found oil hanging off my starter and transmision lines, and all over the bottom of the oil pan.
Do you think this is it?
I have read in the past of someone w/ your complaint and it was the dry sump lines at the connection. Give a look. When I have had a leak and it in several spots I clean everything w/ brake cleaner, dry it and then monitor it everyday till I can see exactly where it is coming from. You'd be surprised sometimes where it comes from and where it ends up. And use a bright light when monitoring.
Received 8,928 Likes
The oil cooler line on my 08Z started leaking last year. The leak occurred where the line changes over from metal to hose. The hoses are crimped to the aluminum line coming from the back of the block. The leak was right over the front spring on the driver's side. Without getting under the car it was hard to tell where the leak was since the oil sort of sprayed everywhere.
Bill
Bill
hardtopz28 (03-25-2016)
To the OP. This happened to my 07' also, same circumstances. Dealer knows what to do (apparently) and it will be fixed under warranty. That or some other TSB applies. Call the dealer and make sure they're familiar with the TSB. Good luck.
This thread is from 2008 I would hope his oil leak has been fixed over the past 3 years
Mods should lock it.
Amoung the things suggested, I've read several posts here on the Z06 side of people complaining about a leaking oil pan gasket. Supposedly a real PITA to replace that gasket, nevermind expensive.
Your car's [hopefully] still covered by warranty, so get it to your dealer to have this remedied. Whatever it is.
Every year mine comes out of storage after 4 to 5 months of sitting still it has oil on the ground under the engine. (left side). Everything has been checked and everything on the engine is dry. Never leaks a drop all summer, no oil stain on the motor. My guess is some seepage from an oil line after extended periods of sitting. Now I just wipe up the floor and forget about it.
z51vett
no oil leak all summer but when it sits for the winter the a few drops always appear.
