[Z06] Gas shortage in NE GA
There is a shortage of gas in and around Atlanta and most of north GA. Most stations that have gas have the 89 and 93 octane bagged, ie, none. I have searched for information on the Forum to get information regarding what happens if only 87 octane is available for my Z06 and all of it relates to blending with octane boosters, etc. If only 87 octane is available, will my 2006 Z06 engine be damaged by 87 octane fuel?
Also, anything current regarding where octane boosters are available will be appreciated. I have a couple of trip upcoming to the Cruisin the Coast (MS Guld Coast) and the Corvette Expo at Sieverville, TN. Once I get away from Atlanta, I am hopeful that 93 octane will be available, but I don't have good information about that.
Any help appreciated.
I wouldn't be afraid to use it if you had no other choice. All that going to happen is the computer is going to recognize the crappy gas after some brief pinging and pull timing. The computer will automatically decrease the power of the motor.
i calculated with 89 for some reason. duh. silly mistake so if you use equal parts of 87 and 100 it will produce 93 octane. so 7.5 gallons of 87 with 7.5 gallons of 100 will yield 93.
There's no real issue using 87 for now...it won't harm the motor. Lower Octane actually makes more power, but can detonate in higher compression motors, hence higher octane required, but your LS7 will be just fine.
The label says "ONLY USE 91 or higher", but it doesn't say "Never, ever, ever use 87 octane"...
I'm in Savannah and none here. Just filled up on Monday at Sam's at 3.79 ? (I think).
It might be worth it to buy some unleaded race gas too.
He probably can only get 87 right now.
So YES, it does say "Never, ever, ever use 87 octane"
What is actually causing the shortage at the pumps?? I heard on FOX news that Georgia and kentucky were particuliarly hit hard with this, but the station gave no real reason for it....
Georgia, Tennessee, and N. Carolina are hard hit for gas around metro areas due to reduced refinery capacity because of the 2 hurricanes. We get all our gas from a pipeline that originates in Houston. Here in Atlanta, there are gas lines extending up to a mile and folks are following tankers to stations. It doesn't affect me since a tank of gas lasts me about 2-months. I think I still have $3.50 gas in the tank! Very few stations (1 out of every 10) have premium gas. Supposed to last another 2-weeks or so before it gets back to normal. Real downer. Never thought I would see gas lines again.
Wil Cooksey #256
Q. I'm constantly hearing about octane booster products. You say 0 to 60® can boost my octane by up to 10 points. What's a point and how does it relate to my car's performance?
A. The term "points" is commonly used in the automotive industry when referring to the octane increase a product offers. This is different from the figures shown at your local gas pump, where the octane "rating" of a gasoline is measured in "numbers". This can sometimes create confusion as to how "points" translate to "numbers". The following calculation can be used to translate points to numbers:
1 octane point = 0.1 octane number
Increasing the octane of gasoline has several positive effects on automobile performance. A higher octane gasoline will allow a car to run smoother by reducing knocks and pings, which ultimately restores lost performance.
An example of this might be:
Common regular unleaded gasoline is rated at 87 octane at the gas pump. If you treat that gasoline with an octane enhancement product that claims a 5 "point" increase, then the end result will be a gasoline that has an 87.5 octane rating. In this example, the octane enhancement product provided 5 "points", which is equal to 0.5 octane numbers.
Prestone® 0 to 60® Booster provides 10 points of octane increase, which will increase the octane of regular unleaded gasoline by a full number. In this case, an 87 octane rated fuel would go to 88 after treatment with Prestone® 0 to 60® Booster.
I think octane booster is a waste of money... IMHO
Hope this helps
Here is a link to more information NOTE they started with a high octane fuel so the results may not be very applicable
http://members.rennlist.com/951_race...omparison.html
From the Prestone website FAQ's:
Wil Cooksey #256
Interesting read... what I use comes from PowerMist racing fuels - and it is not a waste of money. But perhaps what's sold at Autozone is. So I retract that. Go here and buy something that works.
