[Z06] Bend-Pak 4 Post Lift Question - Is HD9-ST wide enough for Z?
Hi guys,
Time to add a 4 post to the garage.
I'm looking at the Bend-Pak HD series 4 posts and need to clarify if the 'narrower' version (HD9-ST) offers enough ramp width/clearance for my C6Z.
There seem to be mixed opinions on the matter - based on my CF searches.
The width of each ramp is 19" - the width of the center section (between ramps) is 37.25" - giving an OS to OS dimension of 75.25". The width of the outside of the back tires appears to be (and is stated online) as 76" for the Z.
What I need to find out is if there is additional clearance between the outside edge of the ramps and the column gussets. (see image below)
I know it's going to be tight, but I really don't have the room for the wider (dash B) version of the lift.
If anyone has the -ST version and a C6Z and knows that it fits, please post back or PM me.
Thanks in advance.
Chris
I Don't Want to Do this
Thanks in advance.
Chris
Hey CaptEJ -
I ran across your posts during my search.. I see you have the same (wide) version as Patches. That 120 3/4" overall width is a bit wide for where I want to put it.
Thanks anyway.
Chris
Thanks anyway.
Chris
The -B is the revision and you can't order an older version. So if you meant you can't fit an HD9-ST-B then you are out of luck because you can't order a plain HD9-ST.
Also, they are actually up to -E.
The ST dimensions as printed will fit a corvette, but it will be a VERY close fit. I find it very hard to believe that the gussets are wider than the mirrors.
The width of your Z06 without side mirrors is 76 in. If you let 4 in on each side for mirrors, that resolves to a width of 85 in. Width between inside of posts is 89 in. Its a little snug but will fit.
Not sure if you mean you can't fit an HD9-ST-B (compared to HD9-ST) or if you can't fit an HD9-B.
It's actually not the mirror width I'm concerned about, it's the outside of the rear tire to outside of rear tire measurement = 76".
The HD-9ST-B is the narrow version of the HD-9-B that a lot of guys on here have (with an overall width of 120.75". That has approximately 82" of 'tire' clearance - plenty for the Z or any other car I'm familiar with.
The HD-9ST-B has 75.25" of ramp width. My understanding after emailing with BendPak is that the crossmember support (circled in red in my image above) adjoins the ramp - aka, there is no extra room.
One of the guys from 6speedonline cut his support and then taped over them with red duct tape to fit his FordGT on the -ST-B version. The FGT has a tire width of 76.9", so I wasn't sure if I could squeeze my Z06 on the thinner version.
I'm hopeful that someone tried it and it fit - I'd really prefer not to have the 120.75" footprint if I don't absolutely need it.
I own a HD-9ST and will confirm that the Z will not fit on it. Not a problem as I keep my 65 on top and ZR-1 underneath.
Mark
Mark
