C6 Corvette ZR1 & Z06 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
[Z06] "Engine drag control active" what does this mean
Old Aug 19, 2009 | 03:22 PM
Coldmale's Avatar
Coldmale
Default "Engine drag control active" what does this mean
Fitted brand new Nitto Invos 345 x 30 x 19 today and from the moment I hit the street, I get that message "Engine drag Control Active" - under even medium acceleration
Anyone know what it means?
John (Bahrain)
Old Aug 19, 2009 | 04:04 PM
Dreamin's Avatar
Dreamin
it means the ECU thinks there is some tire slip in decel and is cracking the throttle to reduce the engine braking effect. very common if you put taller tires on the rear (only).
if you do a search you'll find many threads about it ...
http://forums.corvetteforum.com/c6-z...ol-active.html
Old Aug 19, 2009 | 04:08 PM
RichieRichZ06's Avatar
RichieRichZ06
From: Supporting the Corvette Community at Abel Chevrolet in Rio Vista, CA 707-374-6317 Ext.123
St. Jude Donor '08
John (Bahrain)
It means that you should have changed the fronts to a 295/30/18 at the same time to keep the front to rear tire diameter bias even. The cars have a front to rear split of about 1.1" IIRC, but now you have changed that. It is not hurting anything. The car is warning you that it is sensing the rear wheels trying to lock up and is applying throttle to keep it from doing so. Of course, the rear tires are not really locking up under compression braking, but since you changed the diameter of the rear tires, the car thinks they are spinning slower then the fronts so it does this. Order some 295's for the front and you'll be fine.
RICH
Old Aug 19, 2009 | 05:57 PM
Bill Dearborn's Avatar
Bill Dearborn
Its not the old days anymore. You just can't go around throwing any size tire on the C5's/C6's. You are not alone. A lot of people have been nailed by not doing their homework on tire diameter.
Bill
Old Aug 19, 2009 | 06:08 PM
3LZZ06's Avatar
3LZZ06
_"SCOTT"_
Bill
Isn't that the truth...these high tech machines never cease to amaze me. They've come a long way with all the new technology but you have to play by their rules.
Old Aug 19, 2009 | 06:31 PM
Zoxxo's Avatar
Zoxxo
John (Bahrain)
It shouldn't be doing that under ACCeleration, only under DEceleration.
Z//
Old Aug 19, 2009 | 08:58 PM
DaOtherOne's Avatar
DaOtherOne
Z//
Old Aug 20, 2009 | 01:32 AM
Coldmale's Avatar
Coldmale
RICH
Actually I also changed the FRONTS but to Michelin Cups 265 x 35 x 18 so that mabe made the situation worse
What I am doing is balancing lateral grip and as the Cups are superior to the Nittos in this respect and as 285s are not avaiable where I live and as 295s would have needed a change in wheel width - looks like I am stuck with it.
Does anyone know if it results in a power loss?
John
Old Aug 20, 2009 | 03:46 AM
Zoxxo's Avatar
Zoxxo
John
It does not.
It doesn't hurt anything EXCEPT if you are driving the car hard and are counting on every last ounce of engine braking. In that case you probably have the TC turned off anyway so...
Z//
Old Aug 20, 2009 | 12:19 PM
RichieRichZ06
St. Jude Donor '08
John
295's do not REQUIRE a wider wheel, it is just suggested to run a wider wheel. I have been running them for 2 years on not only PS2's, but also a full set of Hoosier A6's and a full set of R6's. On the track, Auto-x or street there is no issues and the tires work great.
Like others said, there are no ill effects of the "Engine Drag" warning.
RICH
Old Aug 20, 2009 | 01:10 PM
GTABurnout's Avatar
GTABurnout
I went with 285's to go along wth my 345's. It actually kept the ratio very close to stock...
Old Aug 20, 2009 | 01:38 PM
RichieRichZ06
St. Jude Donor '08
Yeah, If you keep the split with in +/- .25" from the factory split it seems to keep the computer happy. Any more or less of a change and it knows.
Old Aug 20, 2009 | 02:37 PM
04_Z06_CE's Avatar
04_Z06_CE
Bill
What ????
There are ton of us guys running the 345's nittos...
No biggie , and the homework wasent all that hard either..
As always Rich with great info
Old Sep 1, 2013 | 10:34 PM
Pete's 08's Avatar
Pete's 08
Cruising
I just got 275/35/18 and 345/30/19 michelins super sports about a month ago, and I get the warning only at high speeds when I down shift from 6th to 4th or so, and even then its only once in a while. It doesn't bother me, but would have looked at 285's or 295's(if available) for the front had I known... oh well. Doesn't hurt anything and I don't physically notice the car doing anything different.
Old Sep 2, 2013 | 01:15 AM
Bill Dearborn
When that happens the EBCM tells the ECM to add throttle to keep the rear wheels from locking up on deceleration. Won't be particularly noticeable except when you don't want to have more throttle when slowing/stopping.
Bill
Old Sep 2, 2013 | 01:42 AM
Pete's 08's Avatar
Pete's 08
Cruising
Bill
Yep, and to be honest with you the hand full of times its happened, I can't say that I've noticed the car do anything. It must be such a small amount t of throttle input that under somewhat normal street driving it isn't really enough to notice...
Old Sep 2, 2013 | 10:10 AM
erikszr1's Avatar
erikszr1
nittos on the rear and Michelins on the front, plus miss matched sizes. uhg..........
To "Engine drag control active" what does this mean
