C6 Corvette ZR1 & Z06 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
[Z06] Dot5 /dot4
Old 09-21-2009, 07:21 PM
jan eric
jan eric's Avatar
Default Dot5 /dot4
Can you mix (correctly/safely) DOT 5 with DOT 4 , as I have now done this?
Old 09-21-2009, 07:22 PM
Shark Racer
Support Corvetteforum!
Shark Racer's Avatar
No. DOT3/4, but not DOT5.
Old 09-21-2009, 08:05 PM
CudjoeScott
CudjoeScott's Avatar
St. Jude Donor '09-'10-'11-'12
Time to bleed those brakes (or the clutch fluid) and refill with DOT4. Bummer, Dude.
Old 09-21-2009, 08:33 PM
RichieRichZ06
Supporting Vendor
RichieRichZ06's Avatar
Location: Supporting the Corvette Community at Abel Chevrolet in Rio Vista, CA 707-374-6317 Ext.123
Received 1,425 Likes on 597 Posts
St. Jude Donor '08
Do not use Dot 5 (Silicone based fluid) in any ABS system.
You have to COMPLETELY flush it out now and start over.
Sorry!
Old 09-21-2009, 08:36 PM
BEZ06
BEZ06's Avatar
DO NOT USE DOT 5!!!!
DOT 5.1 is okay, but don't use DOT 5!!!
Read this:
http://www.stoptech.com/tech_info/wp...fluid_1a.shtml
Flush the DOT 5 out of your system and put in a good DOT 4 or 4+ (which is DOT 5.1).
Bob
Old 09-22-2009, 04:39 PM
jan eric
jan eric's Avatar
I did the Ranger CLUTCH fluid with 3(only) reservoir changes with DOT 5. I am hoping the words 3 only helps me here!
Old 09-22-2009, 04:47 PM
viperZ06
viperZ06's Avatar
these are the kinds of post that give so much value to the forum. guy needs help....gets it. Viper
Old 09-22-2009, 05:00 PM
LFZ
LFZ's Avatar
don't have an answer for you..but I am looking forward to what others have to say for you, since its in your clutch fluid..
Old 09-22-2009, 05:04 PM
RichieRichZ06
Supporting Vendor
St. Jude Donor '08
Originally Posted by American Psycho
don't have an answer for you..but I am looking forward to what to do now since its in your clutch fluid..
Truthfully, the best way to get it all out is to replace the parts. The silicon based fluid will kill the seals and rubber parts in the system. It also does not absorb moisture like regular fluid and will cause the other parts of the system to rust instead of the fluid absorbing it. At least that's what I hear.
Old 09-22-2009, 05:35 PM
CudjoeScott
This backs up RichieRich (not that he needs it ) and is something I found from the Greater Atlanta British Motorcycle Association at http://www.gabma.us/docs/dot5.pdf . Regarding mixing DOT5 and other fluids...
"While it’s permissible to mix DOT 3, DOT 4 and DOT 5.1 brake fluids, DOT 5 Silicone fluid
cannot be mixed with any other type. If the system is not completely purged before
conversion, the mixture may gel and result in very poor braking. Therefore conversion
usually requires disassembly and a thorough cleaning, or at least numerous bleeding sessions
over several days. Obviously then, the best time to consider conversion to DOT 5 is before
rebuilding the master cylinder or caliper."
I would suggest you flush the system thoroughly (multiple times) and then get it to a shop so they can assist you. This sounds like a major job. Sorry for your troubles.
Old 09-22-2009, 07:03 PM
allanlaw
allanlaw's Avatar
Assuming you don't own your own Tech2, you will need to have the system professionally bled using a Tech2 to get ALL of the DOT5 out of the system, including the ABS system. Do it a few times (brake fluid is comparatively cheap) and then keep your fingers crossed. Good luck.
EDIT: Did not notice your later post suggesting the DOT5 went into the clutch system, not the brake system. Disregard my comments about the Tech2 and ABS system. However, I would still do a complete clutch system bleed - not cheap, but really the best idea.
Old 09-22-2009, 07:18 PM
Shark Racer
As he's only done it to the clutch fluid, he's pretty lucky.
I think a couple bottles of cheap fluid followed by a bottle of good stuff should be just fine. Assuming, of course, that he bleeds the entire system on the rack.
Definitely wouldn't trust the master cylinder swap trick for fixing this one...
Old 09-22-2009, 07:35 PM
RichieRichZ06
Supporting Vendor
St. Jude Donor '08
If nothing else, he does have a friendly dealer that will take care of him.
Old 09-22-2009, 07:40 PM
allanlaw
allanlaw's Avatar
I wish we were all so lucky, well, at least me . . .
Old 09-22-2009, 08:13 PM
RichieRichZ06
Supporting Vendor
St. Jude Donor '08
Thanks man. :o
Old 09-23-2009, 01:43 PM
jan eric
jan eric's Avatar
I flushed 32 ounces of Dot 4 using the Ranger method. I auto-xed (Saturday)with the mix of DOT4/5 after flushing in 3 cycles using the Ranger method ,last Friday. When I opened the cap(yesterday) the liquid looked as it did when I added it (a light blue tinge) . I wonder if the silicon DOT 5 floated to the top? Does the Ranger method flush only part of the brake/clutch fluid? Or is supposed to flush all of the liquid? Thanks for the help!
Old 09-23-2009, 01:58 PM
CudjoeScott
It's only a partial replacement of fluid. Old fluid still remains in the clutch system. To completely drain, you need to have it flushed/bled (probably multiple times). There is a bleeder valve on the clutch assembly that is used. I hear it's a bear to get to and some racers have a "quick bleed" installed to make this process easier. I can understand your hesiatation to take your Z to a dealer, but I'd really recommend taking it to RichieRich. His reputation is stellar in here and I've never heard one bad thing about his service dept. JMHO.
Old 09-23-2009, 02:09 PM
RichieRichZ06
Supporting Vendor
St. Jude Donor '08
It does not flush anything. It simply dillutes the fluid a little at a time. Each time you do the procedure, it adds a little more of the new fluid to the system. Because of the design of the system, this is the easiest way to do a fluid change. I would bet you are probably OK at this point. If something goes wrong due to the contamination, you will know.
Sorry we missed the ESCA Auto-X. Our weekends are still crazy since we just got back from the Honeymoon and still have wedding stuff to clean up. I look forward to making as many of their events as possible next year though.
RICH
RICH
Old 09-23-2009, 02:35 PM
jan eric
jan eric's Avatar
Thank you all. Rich hope to see you soon!
To Dot5 /dot4
Quick Reply: [Z06] Dot5 /dot4
