[Z06] C6 Z06 - Drag Radials - size & Type
I want to get a rear pair of Rims & Drag Radials
What Wheel diameter and width, tire manufacturer and size would you recommend.
Supporting Vendor
Location: Supporting the Corvette Community at Abel Chevrolet in Rio Vista, CA 707-374-6317 Ext.123
Received 1,425 Likes
St. Jude Donor '08
Received 2,051 Likes
275/40 hoosier on c5z fronts work for buddies cammed/geared c6z making 555rwhp
Big spread in opinions here.
17 x 9.5" with 275's
18 x 12"
19x12 with 345's
What charateristics would you see form each.
Some say bigger rims just mean more expensive tires.
Other say revs. ramp up better.....
What about grip, I would think that the 345's would be meater.......
What do you guys think........?
18 x 12"
19x12 with 345's
From an engineering view you would like the smallest diameter wheel that will clear your brakes. This in turn increases the tire sidewall which allows the tires to squat when launching (lowering the gear ratio) and grow in high gear (raising the gear ratio).
Watch one of the high speed cameras following a top fuel dragster. The tire/wheel will squat so much on launch that the metal rim will almost contact the concrete. Then in high gear they will grow several inches adding to the mph trap speed.
Having said this, almost any drag radial you can fit will be a huge improvement over your OEM Goodyear Supercar tires.
