[Z06] Gen1 vs Gen2 --Tested at the Drag Strip: the Stock Z06 Goodyear F1 SuperCar Tires
I’ll save you some time and expense if you’re considering buying the Goodyear Supercar ROF Gen2 rear tires for their straight-line traction on dry pavement, including the drag strip. Forget about it. The Gen2 fairs poorly compared to the Gen1. Details follow.
I took the plunge on a pair of 325.25.19 GY F1SC ROF Gen2 tires for the rear of my bone-stock C6Z. Bought them from the TireRack. Total cost of tires and shipping was around $1000. Local mounting and balancing on a Hunter GSP9700 was another $85.00. To do the A-to-B test, also had to buy a new pair of stock comp gray C6Z rear wheels on which to mount the tires ($490 shipped) and the TPMS sensors to make them solid with the car’s nannies (another $85). All told, a $1660 test.
At the same time I bought a new pair of F1SC SuperCar EMTs, the Gen1 that came from the factory on 2006 to 2010 Z06s. Those I had installed as replacements for my second set of rears that were just about to the wear bars at 22.5K miles.
Broke in both sets of new rears for at least 300 miles, with plenty of hear cycles and moderate driving.
Then I did my owner-testing, all involving straight-line, no curves. All tests were done with tires warmed thoroughly by driving (street) or burnouts on the drag strip.
On the street, the Gen2 rears at a road surface temp (not air temp) of 70F, would not hold a throttle-squeeze to wide open throttle from a roll in 2d; a quick shift to 3d at 5500 produces excessive spin that required a lift completely off the throttle. I was shocked. At the torque peak in the mid-4000s in 2d, the tires broke loose. I repeated that test on roads I know to provide good traction. Results were the same.
Took the Gen2s to the drag strip (Maryland International Raceway) and ran 11 passes with pretty good surface prep and a track surface temp in the 70s. Results were poor, even with varying psi ( 27-24) and burnout durations. Best 60’ the Gen2s produced was 1.83. Average was high 1.9x In addition they spun excessively on the 1-2 shift, losing nearly a tenth just on that shift in the 60’-330’ increment. Again I was shocked.
The following day, I swapped to the Gen1 F1SC EMT rears and returned to MIR. Made eight passes in conditions very similar to the previous day. Best 60’ was 1.74, nearly a tenth better than the best on Gen2. Average 60' was low 1.8x, about 1.5 tenths faster. In addition, the Gen1 produced 60’-330’ incrementals (that include the 1-2 shift) more than another tenth quicker than the Gen2. Back to normal performance. I was reassured.
I earlier had tested the Gen1s on good-traction road surfaces at 70s F (surface) temp. They held 2d gear roll-ons well and hooked the 2-3 shift near redline with just a small amount of spin. Repeated the test with the surface temp in the low 60s F. Results were pretty much the same. Bottom line. The Gen1s substantially beat the Gen2s in straight-line street traction.
I readily acknowledge that straight-line acceleration is a secondary concern to some owners, but for many of us, it’s central. I also have no way of knowing whether the pair of Gen2s sent to me are representative of the full production runs in terms of performance. My assumption is they are, since they passed GY production QC.
I’ll keep the Gen2 and run them on the street in Florida where their wet-weather performance may be beneficial. But I’ll be saving the Gen1s for the drag strip.
BTW. Anyone buying the Gen2s ought to weigh them before mounting. The ones initially shipped to me by TireRack…the right rear weighed 32.5 pounds, the left rear weighed 31.0. Again I was surprised at that degree of production variance on a $500 tire. Fortunately, TireRack was quick in shipping me a replacement for the left rear. The new left weighed 32.0, within a half-pound of the right.
I’m sure companies would/did do more comprehensive testing than mine. But the results I got are conclusive enough for my purposes. The Gen1 F1SC EMTs are the ones I’ll be running at the drags on my bone-stock C6Z.
Ranger
Ranger
I suspect someone at GM and/or GY will speak up in the thread some test results defending the Gen2. Hoping so, anyway and would be interested to read their basis for concluding the Gen2's dry straight-line traction is not worse than the Gen1's.
Ranger
As per usual the Ranger has some good information here....Thanks for taking the time.....
Nice write up Ranger. Now do a test comparing the Michelin PS2ZPs to the Goodyears.
Ranger
Thank you, thank you, thank you. I've just crossed the GEN2 tires off my list of possible replacement tires for my Z06. I'm not running on the drag strip or doing any road courses, I'm just looking for a tire that will tame the beast on the street. I want a tire that will hook if I get on it in first or second gear. Appears the GEN2 tire failed miserably in that test.
Anyone know the GM or GY test regime for measuring straight-line grip. I'm wondering if the test spec conditions are confined to surface temperatures substantially higher than 70F I was at on the street and mid-70s on the drag strip surface. If they test at say 90F or higher, perhaps the Gen2 behaves better.
Ranger
Ranger
Ranger
Ranger
_"SCOTT"_
Ranger
Ranger
Thanks for the very costly experiment Ranger, it's greatly appreciated.
Received 2,051 Likes
St. Jude Donor '13
(tagged)
Awesome. I would like to see a comparison between the Mich vs GY. Iam not a fan of the gys. Would like to see manufacteres produce more street/track tires in C6ZO6 sizes with emt.
Were you going to be there when they rent MIR next month? A guy from my area is going and may be able to have him take the wheels/tires down to you.
BTW- they are on repo spyders so I dont know how true the test would be. Just leave a little life left for me.
But I'm the first to say that its been over a year since my factory tires hooked as new, so I am not willing on making a comparison of new-to-new.
As to your comparison above, you are the second person on the forum to say the exact same thing about the new Goodyears....
see post 114...
http://forums.corvetteforum.com/c6-z...post1575916169
As I have mentioned before on the forum, I AM a fan of the stock GY runflats, as they have over performed for me both on the drag strip (1.68 60') & the road course, where in bone stock form I was ALL OVER advanced group drivers in mostly road race set up heads/cam/etc. C5Z's.
After reading about the Gen2's and the results the Bondurant driving school had with them, I figured they'd be a nice replacement for my 15,000 mile GY F1's that were road raced on & drag raced on that are currently on the car. The front's have about 2/32nd's left & the rears are pretty much down to the wear bars.
I DO however notice with this set that once they passed the 13,500 mile mark that they got more slippery AND more noisy. More then I noticed in the past with previous GY F1's.
Ron
Ron
