C6 Corvette ZR1 & Z06 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
[Z06] LS7 with a flat plane crank?
Old 07-13-2011, 08:11 PM
  #141
aggie_corvette
aggie_corvette's Avatar
Just some fun engineering back of the envelope...
IF you wanted to use the LS7 type architecture and make a 180* "flat plane" crank work:
As i mentioned before, Minimize the 2 order harmonics by destroking the engine and making really long connecting rods.
Based on the article above: F1 engines have a Bore/Stroke ratio of 2.46.
The LS7 has a:
bore: 4.125, stroke: 4.0 in.
Destroking the LS7 using the same bore/stroke ratio of F1 would yield a:
Bore: 4.125, STROKE: 1.68 in.
This makes the new displacement: 179.6 cu in (2.94L).
i would round these to 180 cu in (3.0L).
I would bet this engine config. would rev like crazy!!! assuming the top end could handle it...
If i was restricted to a 3.0L racing class this would be a great base engine to start with. Compact in size, low weight/mass, low CG, ect.
For the street, you would lose all the TQ and some HP but it would sound fantastic.
Old 07-13-2011, 11:06 PM
  #142
4GS7
4GS7's Avatar
Old 07-14-2011, 10:02 AM
  #143
aggie_corvette
180* Flat plane vs 90* Cross Plane V8s
Ferrari 180* Flat plane V8
LS 90* Cross Plane V8
Old 07-14-2011, 10:53 AM
  #144
Everett Ogilvie
Everett Ogilvie's Avatar
Outdated Antique!
Quick Reply: [Z06] LS7 with a flat plane crank?
