[Z06] Oil Plug Seals
Unless they are damaged, no.
Yes, you have to remember to replace both oil pan drain plugs and also put in the right amount of oil for the MY Z06 that you have. I understand not all Chevy dealers can handle that complex process. (yes, you have to get it up in the air somehow and back down, except for one poster here that does it all with the car on the ground!)
It probably wouldn't hurt to replace those rubber seals (there is a separate GM part number for them) every five changes or so just to be on the safe side as a good practice. Time and temperature will eventually degrade the rubber. You wouldn't be happy to do an oil change and later find the plugs seeping oil.
hate to dredge up an old thread, but what is the part number for the oil plug seals?
EDIT: is this it? 14090908 - Gasket - Engine Oil Pan Drain Plug Seal
My drain plugs are seeping. The front sump line too. Not bad just develops an about to drip. Never hits the floor, just gets a small amount of oil in a couple of spots.
