C6 Corvette ZR1 & Z06 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
[Z06] Cam/Headers Question...
Old 12-05-2012, 04:52 PM
  #41
'06 Quicksilver Z06
'06 Quicksilver Z06's Avatar
Originally Posted by Mookster
Guess i always wondered about how would one determine gas quality in their area?
Most people who determine it, determine it the hard way.
But the thing is, if you get some of it, it might or might not cause trouble right away, and you may even forget where it came from.
Boron had some crap gas out there a few months back.
http://www.nbcchicago.com/news/local...166942586.html
http://chicago.cbslocal.com/2012/08/...hwest-indiana/
This is just one way gasoline can be "tainted". Lower octane than stated can also hurt you.
Old 12-05-2012, 05:03 PM
  #42
2000FRCZ19
2000FRCZ19's Avatar
St. Jude Donor '12
Originally Posted by Sm5654
What does gas quality have to do with milling the heads?
it bumps compression up. if the octane isn't high enough you will get into problems with detonation. if you have 93 in your area you should fine.
Old 12-05-2012, 05:05 PM
  #43
Sm5654
Sm5654's Avatar
St. Jude Donor '13
I've never seen a gas station in north tx that didn't have 93. Guess its readily available in the metroplex
Old 12-05-2012, 05:14 PM
  #44
Mookster
Mookster's Avatar
I have never seen 93 in Seattle area, standard at gas stations is 87, 89 and 92...wonder if 92 would be OK to use? Thats what i currently use...
Old 12-05-2012, 05:18 PM
  #45
screaminchevy
screaminchevy's Avatar
Pat tuned mine for 93. he can tune it for 91 if you'd like but there's really no need. He also backs off the timing just a smidge for saftey sake like any good tuner should do. an extra 3-5hp isn't worth the risk of detonation from bad gas.
I drive around on a nitrous tune with a the timing backed off even more. It made 580 NA giving it as much timing as we could on the dyno, backed it off the tune for spray and it made 575, so it's really not going to matter.
Old 12-05-2012, 05:30 PM
  #46
Sm5654
Sm5654's Avatar
St. Jude Donor '13
Pat is pretty good at what he does huh?
Old 12-05-2012, 05:36 PM
  #47
screaminchevy
Old 12-05-2012, 06:05 PM
  #48
millerjj
millerjj's Avatar
I made 545 cam and headers
I made 589 with cam, headers, WCCH heads, fast, n/w T/B & B&B fusions
Old 12-05-2012, 07:27 PM
  #49
lilredvette05
lilredvette05's Avatar
Yeah Pat knows his stuff, my TQ numbers kinda sucked to me at 481 and that's with H/C/I. I wish I still had my factory wheels to see how much the 345/25 on 20X13 makes a difference. As far as gas goes he tuned mine for 93 and and a actual gas hauler for a living I can tell you, you can get bad gas anywhere. There's companies out there that will load a generic gas if the good stuff (branded gas) is out at the refinery. Usually go somewhere where their real busy and that means they will usually have fresh gas most of the time. Where I'm at now I fill up on conventional gas 93 with no ethanol
Old 12-05-2012, 08:22 PM
  #50
Sm5654
Sm5654's Avatar
St. Jude Donor '13
What were your torque numbers?
Old 12-05-2012, 08:54 PM
  #51
'06 Quicksilver Z06
Originally Posted by lilredvette05
.... As far as gas goes he tuned mine for 93 and and a actual gas hauler for a living I can tell you, you can get bad gas anywhere. There's companies out there that will load a generic gas if the good stuff (branded gas) is out at the refinery. Usually go somewhere where their real busy and that means they will usually have fresh gas most of the time. .....
I have heard this before too.
I have also heard of stations filling the 92 Octane tanks with 87 Octane and selling the 87 octane for 92 octane.
Old 12-05-2012, 09:23 PM
  #52
lilredvette05
Yeah that happens if we accidentally mix, the company will eat the price difference if we mix 87 into 93 while the station still advertise 93. This is vary shady as the stations don't realize some cars depend on higher octane
Old 12-06-2012, 06:11 AM
  #53
Turbosixx
Turbosixx's Avatar
Milling the heads increase the compression ratio, which in turn requires more octane. With a good tune you should be fine with 93 octane.
As far as headers go.. My car dyno'd 520 with just a cam and vararam intake. I then had the heads milled .030" and installed Kooks 1 7/8" long tubes and dyno'd 557/542. I'd say the headers and milling the heads are definitely worth it.
Old 12-06-2012, 08:00 AM
  #54
millerjj
millerjj's Avatar
The 589 was 510 Tq
Here is a copy of the one I found on my computer
Old 01-08-2013, 11:59 PM
  #55
Sm5654
Sm5654's Avatar
St. Jude Donor '13
UPDATE: Ended up getting American Racing headers and no cats along with a C5R timing chain (for my piece of mind) and all the previous listed mods. My cylinder heads have been at WCCH for about a month and should have started their journey back to TX today. Stay tuned for dyno video and numbers... should be up next week. 5 weeks without the Z feels like a freakin eternity! Almost there
Old 01-09-2013, 05:37 AM
  #56
427 Pilot
427 Pilot's Avatar
Subscribed
Quick Reply: [Z06] Cam/Headers Question...
