[Z06] Every Tech should have this LS Timing cover Alignment Tool!
Supporting Vendor
Supporting Vendor
^^^^^+1 on that one. Used mine the other day to install my front cover went on perfectly and the frt seal installed correctly also with the tool.
Supporting Vendor
I used mine last week. Worked like a charm to hold everything in place while I got the bolts going and then worked perfectly to drive the new seal in.
Supporting Vendor
Thanks for the good word and you business.
Do you have any pictures of why the AlignIt tool couldn't install the seal on that combo?
Christian
I guess I could reverse it to push the seal into the timing cover. My next LS7 dry sump build that uses the LS3 front cover, I'll try it. The Kent-Moore front seal installer doesn't work in this application.
SacCityCorvette (04-19-2016)
#33
Supporting Vendor
Supporting Vendor
Planning a cam swap or engine rebuild? AlignIt Tools can help with the rear main, timing cover and seal install. And get it done right the first time with less chance of leaks!
#36
Supporting Vendor
Hi 3x2,
Yes we do and here is a link
http://hstrial-saccitycorvette.homes...gnItTools.html
Thank you
Christian
Thank you
Christian
__________________
Don't forget to check out our products at www.saccitycorvette.com
If you like our products, tell others! If not, tell us!
#37
Supporting Vendor
Here is a simple but very effective tool to help you make easy work of aligning your LS1-2-3-6-7-9 Timing Cover, Rear Main Cover. They even install the seals.
#38
Supporting Vendor
Hi all!
If you're doing an engine build or cam swap, these tools will help prevent premature seal wear and leaks.
https://www.saccitycorvette.com/AlignItTools.html
Also, while doing that build or rear main seal, its a good time to install our Billet Barbell to help keep unfiltered oil out of your bearings and lifters.
Check out our Billet Oil System Improvement Parts.
https://www.saccitycorvette.com/OilS...provement.html
Thank you,
Christian
Thank you,
Christian
#39
Supporting Vendor
We have the AlignIt Tools in stock and ready for same day shipping!
__________________
__________________
#40
Supporting Vendor
We hope everyone is doing well and staying safe during this crazy time of the virus.
Just wanted to let you know, while we are practicing the virus safety precautions, we still have our same day shipping of our products.
Stay safe and let’s get through this!
Christian
SacCityCorvette
Christian
SacCityCorvette
