C6 Corvette ZR1 & Z06 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
[Z06] Every Tech should have this LS Timing cover Alignment Tool!
Old 05-30-2013, 02:40 PM
SacCityCorvette
Supporting Vendor
SacCityCorvette's Avatar
Location: SacCityCorvette.com in Sacramento Ca Join us on Facebook!
St. Jude Donor '12,'13,'15,'16,'17
Default Every Tech should have this LS Timing cover Alignment Tool!
AlignIt Tools are used to align the Rear Main and Timing Covers and install the seals!
Whether your a Pro or a Do Your Own Repair kind of guy, here is a simple but very effective tool to help you make
easy work of installing your LS1-2-3-6-7-9- LQ4-LQ9- 5.3-6.0 and all GM v8's from 1997-2013 Timing and Rear Main cover and seals. Works with all LS based engines!
Here is a couple simple but very effective tools to help you make easy work of aligning your Timing and Rear Main Covers. CNC Machined to exact tolerances, the AlignIt tools
get the covers centered perfectly with the crank. The O-ring design makes for a perfect snug fit no matter the temperature that can cause expansion/contraction of engine covers, crank & tools
that will hinder a perfect fit. The O ring design eliminates this problem. After the covers are centered and torqued down, use the AlignIt Tools to install the seals in seconds!
Available in the Pro Series 6061 Aluminum Anodized and the standard PVC Plastic. Both are CNC Machined to exact specs
from Billet materials.
www.saccitycorvette.com/AlignItTools.html
If you're doing a Rear Main Seal or Engine Build, its a good time to start keeping unfiltered oil out of your bearings and lifters! Check these Billet Oil System Improvement parts out!
https://www.saccitycorvette.com/OilS...provement.html
__________________
Don't forget to check out our products at www.saccitycorvette.com
If you like our products, tell others! If not, tell us!
Old 05-30-2013, 05:31 PM
erikszr1
erikszr1's Avatar
Nice!
Old 05-31-2013, 02:10 PM
SacCityCorvette
Supporting Vendor
Thank you!
Old 09-14-2013, 08:01 PM
NHRA95
NHRA95's Avatar
Very nice!!!
Old 09-18-2013, 04:49 PM
SacCityCorvette
Supporting Vendor
Thanks NHRA95!
Old 02-14-2014, 03:33 PM
SnyperZ
SnyperZ's Avatar
Wow..where were these 5 years ago? haha
Old 02-17-2014, 09:12 PM
SacCityCorvette
Supporting Vendor
That's what I was thinking!
Christian
Old 03-28-2014, 06:43 PM
3X2
3X2's Avatar
Mine arrived today. Can it be used with the oil pan on? The one I got has an o-ring on one end. Does that go towards the oil pump or away from it? The one in the video doesn't have an o-ring.
Old 04-08-2014, 03:03 PM
SacCityCorvette
Supporting Vendor
Thank you for your business!
You have the latest tool with the Oring. The Oring goings toward the engine into the cover.
Christian
Old 09-08-2014, 11:59 PM
SacCityCorvette
Supporting Vendor
The Hub Simulator Tool is for those that do not want to remove the seal.
It simulates using your hub to align the timing cover with the seal in place.
Old 09-26-2014, 02:38 PM
rwheelz
Support Corvetteforum!
rwheelz's Avatar
Ordered because of history lesson!
Old 10-07-2014, 02:14 AM
SacCityCorvette
Supporting Vendor
It sounds like you went to the school of hard knocks.
Old 10-07-2014, 08:39 AM
rob20rx7
rob20rx7's Avatar
have my timing cover off right now. glad i saw this post. just ordered one. hopefully you guys can get it out quick to me.
Thanks!
Old 10-07-2014, 12:36 PM
SacCityCorvette
Supporting Vendor
Thanks!
It's packed and ready to go,You will get it in 2 days
Old 12-02-2014, 02:22 PM
blown81bu
blown81bu's Avatar
i want all 3?...Paypal?
Old 12-02-2014, 02:53 PM
SacCityCorvette
Supporting Vendor
Hi blown81bu,
Here is the link. PayPal works!
http://www.saccitycorvette.com/Timin...nmenttool.html
Thank you,
Christian
Old 12-26-2014, 08:52 AM
rob20rx7
rob20rx7's Avatar
Default Awesome Tool
Works perfect everytime!
thanks !
To Every Tech should have this LS Timing cover Alignment Tool!
Old 12-27-2014, 08:32 PM
SacCityCorvette
Supporting Vendor
Thanks for the good word, rob20rx7!
Christian
Old 03-11-2015, 04:36 AM
Mark Wade
Mark Wade's Avatar
Just ordered 4 sets on their way to New Zealand tomorrow i think , I did make one for the front seal out of an old pulley but cant be bothered making a rear one for what these cost , mind you our dollar only 71 cents, but still good value so will distribute the other 3 sets to other engine guys , thanks
Old 03-13-2015, 01:30 AM
SacCityCorvette
Supporting Vendor
Hi Mark:
Yes they are on the way.
Thank you for your business.
Norma
Quick Reply: [Z06] Every Tech should have this LS Timing cover Alignment Tool!
