[Z06] Ranger Method
I can't find the link to the video of the Ranger Method for clutch fluid replacement. I saw it and forgot where.
This seems to be a much discussed topic.
How big a deal is this? My car has less than 7k miles on it. My local Corvette shop used a turkey baster. They suggested this was what "most" owners relied on. I have an idea on how it might work but I would like more info any other thoughts on an 08 clutch and fluid.
Googled: Ranger Z06 Method. This was the result.
http://www.rangeracceleration.com/Clutch_Care.html
http://forums.corvetteforum.com/c6-c...er-method.html
http://forums.corvetteforum.com/c6-z...-and-cure.html
Buy the correct spanner and a pressure bleeder and do the job properly or pay an expert to do the job correctly. It is IMPOSSIBLE to reinvent the laws of physics. And as I have said before doing it right the first time is quicker and cheaper than puffing and blowing on the master cylinder which is basically a waste of time. And if you think I am wrong thats OK - I am not wrong - go and ask any decent hydraulic expert and he will confirm after laughing his head off at the idea of bleeding the slave from the master cylinder filler.
If you do the correct bleed below using a pressure bleeder you can't go wrong... You are not playing with a $100 rustbucket - surely an expensive performance car deserves correct servicing.
http://forums.corvetteforum.com/1583666941-post26.html
