[Z06] Just a Q on which z06 you would pick?
which z06 should i buy? i plan on driving it everyday to work and back
im looking to keep it stock and org wanted one with a warranty bc of the valvetrain issues bc i dont have 12k to buy an new ls7
but then i found number 2 for the same price packing 550 to the wheels
both z06's are the same price
1. 2008
black
40k miles
1 owner
all stock
3yrs and 80k miles left on the warranty
2. 2007
2007 LeMans Blue
31k miles
GT20 cam
Lingenfelter LS7 heads
LG long tube headers
Corsa exhaust
no warranty but has the heads from LPE so i shound have a problem driving this for the nxt 5yrs
what are yalls opnion on the 2?
Get the modded one. If this is a daily driver, odds are you will rack up miles quicker meaning that your warranty will run out quicker. Its always best to get a vehicle which has the heads addressed. The only issue I see with it is that with the aftermarket cam you will experience a cam lope which might affect daily drivability.
Received 19,234 Likes
'20-'21-'22-'23-'24
I'd probably go with option 2 but it would depend on who did the engine work on the car.
The Z06 is an amazing car stock. If I wasn't out of warranty I most likely wouldn't mod it.
I would go with option 1. More value in it. I stay FAR away from modded cars as its a good indication on how it was used. Don't forget the engine is only part of what can go bad. Abuse wears everything out and increasing the HP beyond stock makes it wear quicker.
Option #1 and enjoy it until the warranty expires.
BTW who is the warranty with?
Option 2.
the orginal owner bought it in 2008 cash for his son and purchased the 8yr 120k warranty
i talked to a local dealership and said i could also extend the warranty as long as i did if b4 the orginal one was up
#1 for sure if its a GMPP warranty. Enjoy the car worry free for the next 3 years.
Received 8,919 Likes
Also on the question of who is providing the warranty coverage. GMPP Major Guard is good. As with most modern cars there are more issues than drivetrain issues. The Z06 is an oddity because of the valve drop issue but there is a reason why car manufacturers offer extended duration drive train warranties. They don't usually fail. Major Guard will cover all of the very expensive electronic items that are not part of the drive train. Don't say you can repair them yourself unless you really know how to diagnose electronic issues and can afford to pay the stiff parts cost.
Bill
If you go with #1, and plan on extending the warranty, make sure you have the owner
sign a transfer within one month of purchase or you will not be able to purchase a extended warranty.
Option #1 - anything that breaks on that car is expensive. Also, verify what is covered under that extended warranty before you purchase it, and make sure it's transferable to the new owner.
The color is awesome, the heads "should" be good depending on what options were installed, and the rest of the mods are basically FREE on a car with lower miles. There are plenty of guys here that spend tens of thousands building up their cars... to park them at car shows every third weekend. IMHO, when you buy a used car you take your chances regardless of the known mods. I can't count how many "back to stock!" sales of performance parts I see on these forums; who knows if the ECM is original or not, what parts were on the car at one time and taken off, etc.
If the cam lope is not a turn off... there's several thousands in free mods on that car. If you ever thought to do an exhaust or a CAI - that's $1500+ right there you don't have to spend, and could put towards rebuilding the Lingenfelter heads as a project later on.
I'd say the better value is Option #2 hands down - the question remains, which car will help you sleep better at night? An unfixed "warrantied" car or a car that might be fixed but would be loads more fun (and look better doing it)?
Don't get me wrong, I'm typically a warranty/keep it stock guy... but given the age and mileage of these cars (and the potential hassle of an extended warranty); I'd lean towards the LeMans Blue.
The color is awesome, the heads "should" be good depending on what options were installed, and the rest of the mods are basically FREE on a car with lower miles. There are plenty of guys here that spend tens of thousands building up their cars... to park them at car shows every third weekend. IMHO, when you buy a used car you take your chances regardless of the known mods. If the cam lope is not a turn off... there's several thousands in free mods on that car. If you ever thought to do an exhaust or a CAI - that's $1500+ right there you don't have to spend, and could put towards rebuilding the heads in a few years.
i allready went down the 35k in mods to make a car 1000hp capable
.....its been in the shop for 3yrs
i know a c6z isnt the fastest thing on the road and i dont want it to be
i want a bad *** car that i can drive everyday and not worry about replacing a 12k stock motor on my way to work bc i couldnt afford to replace it
ganted the LMB has all the mods and power i would want anyways period in the time i own the vette , i just would be in a HUGE hole if it took a *****
Find out WHO did the head install on #2, and what Lingenfelter package was selected (ie a receipt) - if it was a professional shop I think you'd be more or less in the clear and better than stock.
ETA: You have the same risk in the unmodded car - if anything many would think your risk could be greater in the stock car. You just can't know either way until you pull the heads, which is why the "valve issue" is such a big sting - no one wants to cross their fingers and wait.
The only difference is who's going to pay for the rebuild? A warranty might actually cover the rebuild, but you have to think about all the used parts they're going to recycle, how long it stays in the shop, etc if/when that stock car drops a valve.
and having a valve drop is catastrophic engine failure
****ed up head/piston/cyl walls ......ughhh
maybe i just cant affored a z06 bc the motor might GRENADE
and why are the ls7 crate motors so damn costly?
