[Z06] Car lift in home garage?
Looking to install a lift in my garage, the only problem I see right now is how to get around the traditional type garage door that has the opener in the middle of the garage.
I do not know if there was a different style where the opener is on the side of the garage or a roll up style that will work.
I have the height in the garage but not the depth to get far enough into the garage where the current opener will work with a lift in there.
Thanks,
Thanks,
If you want to replace the opener...lift master makes a great side opener...
I had a Atlas bp9k in my last garage. Worked great. It was deep enough that I didn't have to mess with the doors though.
You can also retrack your current setup so the door opens all the way to ceiling height instead of like 5 feet suspended down. That may give you enough height depending on your setup
There is a lot of good info and some good pics in here:
http://forums.corvetteforum.com/c6-c...age-folks.html
Received 8,928 Likes
It also depends on what type of lift you purchase. A mid rise scissors lift will pretty much allow you to put a lift in any garage. It will get the car 4 ft off the ground which is high enough to ride under it on a small seat. Max Jax lift is another way around obstructions.
Bill
Bill
When I was younger I paid my dues changing clutches with a 914 on jack stands in my driveway (of my mobile home) with the trannie sitting on my chest, so I could drive it to work the next day.
getting older has many downsides...but a lot more upsides.
I did this to my 2 car garage.... installed lift on left side and right by the rail. When the car comes up on the lift you miss the rail. I also moved my garage door opener to the right side off the door as the above picture and out of the way.
You might be able to get away without changing the rails as I did by taking a few measurements.
My garage door opens only to a height to get a car out when the lift is up.
The height it opens allows either car to get out.
When the lift is lowered then the garage door opens all the way.
