[Z06] MGW short shifter vs C6Z OEM Stock Shifter
What's everyone opinions on the MGW shifter over the stock shifter? I've heard that it's harder to shift into 3rd with the MGW than the OEM shifter. Also, getting it in to 1st and reverse can be a bit of an issue. Looking for some reviews before I spend $350-400 on a shifter that's worse then stock........
hey man I was in the same boat as you but ended up ordering and glad I did,theres no issues with shifting in any gear,it feels a lil notchier but I actually like how it feels much shorter throws n no wiggle from the shifter when in gear.
I only installed the ssk without the lower box and its fine
just installed MGW last week
pay attention to install and (my experience)
1- it is shorter throw - by about an inch- not a huge difference but nice "new" throw
2- it is solid shift feel stock = 6/10 MGW = 9/10
3- it is quiet as or more so than stock
4- No issues whatsoever with any gear operation
Good luck
Good luck
No problem with first or third, in fact third feels great! Reverse is a little more effort but the trade off is more than worth it to me. Also 6th is a little more effort just due to it being shorter and notchier and all the way right/down (you just have to be paying attention) but you'll never be shifting quickly from 5th to 6th. All the gears you want to grab quickly (1-2 2-3 and 3-4) are awesome.
I just put one in last week also. feels crisp and shifts smooth. Im thinking of cutting about half an inch on the stick so i can drop the shift **** to the lower hole just to storten the stick a little more.
I absolutely love mine, gear operation is awesome, and i love the more "solid" feel the MGW give you
I thought it was a great improvement going from stock to MGW, but what really solidified it as an amazing purchase was driving a couple Zs with the stock shifter after driving with MGW for about a year.
The stock Z shifter/action feels is so cheap and disconnected, it's amazing they were allowed to leave the factory like that.
Selim Bradley (06-06-2022)
I am also interested in this shifter, I read in another thread that installing the MGW shifter actually helped one guy's reverse problem. That would be my issue, I already have a hard time engaging reverse as it is, will it make it better or worse?
I dont think the shifter itself will solve an issue of getting into gear. It will help you with the shorter "throw". It may be a clutch, linkage or synchro issue ?
Night and day difference. MGW is 10X better than the sloppy stock shifter. Had mine for over 15,000 miles - no rattles or vibration either been though I bought an earlier made one.
Go for it you will love it.
I'm not so sure its worth the money IMO. I have a 2007 Z and I'm thinking about going back to stock shifter possibly. Makes it harder to get into 1st and also 6th gear. I've had it taken apart and re-installed by 2 different competent shops and it still doesn't feel quite right. Maybe its because I have T-56 vs 6060 but I was a little dissapointed given that everyone was raving about this thing. I purchased every piece they sell including the lower shift box etc..
Yeah I guess its hit or miss than... Like I said I've had 2 different competent shops take it apart and re-install it and it still has never felt perfect. Wish I did't sell all my old parts because I would try and go back to stock and feel the difference.
Did you WTT your MGW for a stock shifter?
If you've ever had a short throw in any other car it's the same story, different day. Crisp and more precise shifts. The 2-3 takes some adjustment, but its no big deal. Basically just have to use your palm and give it a VERY slight side/upwards push. It becomes second nature after a week or two. I have no problems with reverse or 6th. Granted I drive an 18 speed most days, so anything will feel precise after dealing with that. Try going from that and matching revs to speed/powershifting at the track. Weird feeling...
