[Z06] How much power can a naturally aspirated LS7 make?
I used to have a C5 z06, and now I have a Viper GTS, so I've lost touch with the vette world.
I met someone who claims to have a 660rwp C6 Z06 with no power adders. I've only briefly heard the car, and while I do hear a lopey cam, it doesn't sound any wilder than that.
Is it really possible to make that much power without a power adder?
What kind of numbers would a C6Z with an aggressive heads/cam package, with full intake and exhaust, typically make?
He's specifically telling people that it dyno'd at 660. I thought that sounded awfully high. He won't tell anyone what's done to the car. I'm not sure if it's because he doesn't know, wants to hide what's done, or not that much is actually done.
It seems like this is an oddity though, no?
My thoughts..
My thoughts..
thereason1 (04-27-2020)
How much does a heads/cam/intake package like cost with parts and labor?
Different dynos will read different numbers. Trap speeds will tell the real story, as a 660 rwhp C6z should be 140+, and you don't see that much unless you have a stud at MIR or Etown. In all my years of seeing NA LS7s across the country, they are typically 13x traps, which is not 660rwhp. Not saying some aren't, but am saying most aren't.
We have a 7% variance in dynos between the top 2 speed shops right here in Detroit. One is right on the money in my opinion (stock LS7 hitting 447), and the other is 7-8% higher every time for the same car. Just the nature of a dyno.
$2-$3k for the heads/porting
$500 for the cam
$1800 for the exhaust
$2k for the cai, intake, tb
$2k for the install/fluids/gaskets
So, $9-$10k?
Here's one documented build from a forum member.
https://www.corvetteforum.com/forums...-102mm-tb.html
With that being said, 750 rwhp can be achieved with a more aggressive setup.
SaberOne (05-03-2019)
Dumb question... why does a destroked smaller C.I. engine make so much more power?
Thanks, my initial thoughts were that it wasn't an easy task to hit those numbers.
no doubt
It would nice to find a discounted Z with a blown motor and then do a build like this. Maybe I could save $5k..
yeah but you're probably looking closer to 15K for a 600+whp heads/cam setup with a a good set of heads
Would it be correct to say that the people that are making 660 to the 750 you mentioned would really be the pioneers of pushing the limit and wouldn't represent most people with heads/cam/intake and other typical bolt ons?
yes
It can if it is designed correctly to utilize rpm to produce the power and still maintain reliability, but this comes at a price that most people aren't willing to spend or comprehend, unless you can find one as good as new for 1/2 the price!
no doubt
yes
If I wanted the best value for my dollar on a naturally aspirated build, there is probably a point where the cost for more power starts to increase dramatically. Where would a heads/cam/intake package (with supporting bolt ons) that is considered a good value, get me power wise?
You're right, let me ask that question in a better way..
