[Z06] R&Ring re-guided ported heads next week... questions
Any 'new" short cuts or tips other than the DIY that I should know? I plan to have everything ready to go for a 2-3 day swap. As I can't work 8 hours on a car in 1 day anymore.
Derek!
Derek!
Ok searching... can I reuse my coolant crossover pipe plugs?.. do they use o rings like the ls1? Or do I have to get new ones? Just preparing.. cause I know there will be sh#t happening at my age when I start this! My 30th rodeo but I (my joints) don't like bucking broncos as much as I did in my 20's and 30's.
Thanks for any gear heads left on the C6Z forum.
The steam vents use orings I didn't have new orings so I reused the ones on the front and had no problems. The rears are blocked off from the factory with a rivet in the hole. If they left them in then you're good to go. I had my heads done by AHP and they included new block offs for the rear since they removed the rivets while cleaning
Thanks redbird.... yeah I always prefer to use arp head bolts over the gm tty bolts which I don't really care for.. thanks for the tip on the coolant plugs.
Doing some upgrades Derek, or just preventative maintenance?
I would change those O-rings. When I put something back together I really hate having to f with something simple that shouldn't have happened if I had replaced a gasket or part but didn't.
If you are pulling heads off you will use new head gaskets correct? Get the head gasket kit from GM it will come with those O-rings and a few extra parts that makes them easy to replace when everything is apart.
I did new O-rings on that coolant bleed line, PS lines and also did a new cam retainer plate instead of reusing mine (has a gasket moulded onto it in the back). Easy to replace instead of having to tear it apart again if a problem develops.
Tony
Tony
Thanks Tony.. already bought gm head gaskets.. i can get o rings.. motor is 12k miles and clean... just a head swap.. no cam....
Mike I will PM you later bud..
