[Z06] Might Mouse catch can review
#41
Supporting Vendor
I have had several guys use two passenger valve covers (like the copo car does) in order to get two massive ports.
keep in mind we can support 1200hp with a single port (my 12an adapter).
http://www.mightymousesolutions.com/...a-02d6fe2ab2d3
#42
How do u come up with your HP ratings? Do u have crankcase pressure data to compare a stock setup to what the OP has?
#43
Well the number 6 would make sense for up to 500-600 hp as that is what comes with our cars to begin with. The 3/8 plastic line going up to accordion thing from the oil tank. The PCV valley cover hole we have like mentioned above really does not flow much since it is just an 1/8 inch hole.
#44
Supporting Vendor
#45
I was pissed that I had to pull the intake, but it worked out for the best after all.
In retrospect, I should have just gone with one of these MM cans. I probably will eventually.
Dan_the_C5_Man (05-19-2017)
#46
According to something I read, the hole is 1/10 of an inch 2.5 mm.
#47
Supporting Vendor
Excellent idea! Ready when you are.
__________________
Solutions for the common gearhead #made in USA
facebok.com/mightymousesolutions
#mmsolutions
Six time NMCA True Street Champions
Home of the first Twin Turbo C7Z 7.81 @ 176
3470# Stock bottom end and heads Corvette Stock Bottom End Record Holder
#mmsolutions
#48
My experiment failed because I removed all restrictions from the valley connection, NOT because I used it.
It is a pet peeve of mine to cherry pick words to support an argument or position. I in no way implied the valley is a bad place to vent from.
#49
Supporting Vendor
there was no cherry picking sir, additionally i have no argument or position, only friendly guidance.
with the restriction in place it is a bad place to vent from
with the restriction removed it is a bad place to vent from
all times it is a bad place to vent from, no matter who tries it is or what they do. nothing personal about it.
in stock application it is the pcv return, not a crankcase vent.
so unless you are using it as part of pcv control, it is useless.
#51
Thanks for the pics and feedback MD - as I read through the thread, I was thinking, "hmm, maybe open up that orifice in the valley cover", and sure enough, you did it and saved myself and others the trouble.
One of the reasons I didn't want to pull from the valve cover is I (assumed) the oil misting / baffling would be inferior as compared to the valley cover.
#52
Supporting Vendor
Because I have measured the flow personally, and it is a platform and system I have been working with for 17 years. Not only is it's contribution to crankcase pressure ventilation negligible, it is also unreliable.
No reason to get upset. Just trying to save some good people here their time and hard earned money. Good luck to you.
Bad Dad (05-19-2017)
#53
And as I've stated a couple times already, I will eventually add one of your cans. I will not, however, eliminate the valley vent unless I can fully understand your position.
#54
Valley cover vent is great for cars driving around town. It does its job when the manifold is under vac and fresh air is circulating through the engine - which is an emissions requirement and for oil life. At WOT on a stock engine most of the crank pressure (unfortunately) will go out through the valve covers and into the intake accordian (reverse of pcv's general direction). The valley cover fitting now sees only ATM pressure as the manifold is no longer vac in which reduces measured flow even more.
By blocking this vent the overall alibity to remove crankcase pressure is not greatly reduced (under WOT). However, you do remove pcv system functionalty (which not everyone cares about). You then allow for only 1 point of venting and 1 point of control to worry about oil coming through, hence why MM designed the system this way. The valve cover line size is increased from stock to allow greater hp cars to vent appropriately without blowing seals and catches oil mist that may accumulate.
If you so choose - you can keep the stock valey cover line going to the throttlebody but you will create another point of possible oil entrance (as you have noticed). This would pi$$ a customer of MM off because they would be getting oil in their manifold even after buying their product (and I am sure asking for money back).
GM tried by putting baffles on the valey cover and controlling flow via hole size. By controlling internal pressure on a high hp build with appropriately sized valve cover vents, the stock pcv location should not consume more oil than a stock powered engine does.
In all of this...it is your decision if you want to run both venting options. Just understand MM wants to control a single point of entry to ensure a dry manifold instead of relying on GM's design alongside their product.
