[Z06] Adding high flow cats to offroad xpipe
can i just buy a set of high flow cats and install them on my offroad x-pipe?
Does it require alot of cutting and welding?
or it would be better to buy a complete catted x-pipe?
Depends on what brand. LG systems they just bolt right in, super simple. Other systems you would have to cut/weld or replace the xpipe.
I would recommend these...Random Technologies has a good reputation...but they're $205/ea. http://www.hinsonsupercars.com/p-928...-metallic.aspx
I assume that I will need to cut some length of the offroad xpipe and the cats can be bolt on with clamps. Is that correct?
Probably with enough cutting/hacking/etc. Depends where they put the x on the kooks. If you have a kooks system your probably best off just ordering a kooks catted xpipe.
I sent you a PM. Not certain if you received it. I have a catted Kooks mid pipe on my c6z and have been looking for a used catless Kooks mid pipe. I would be willing to trade + a little bit of cash if you're interested. I only have right at 3k miles on mine.
