[Z06] MTBSully's 08 Z06 Winter 2017 Build (E85, MSD, Heads Etc)
#41
Yea and there's other people claiming they've been running that walbro 450 for 2 years plus no issues , I can tell you that there's a few guys around my area that have been using the stock pump for some time now and one guy makes 630whp (he's been on the stock pump for a year) of course they're running bigger injectors
#42
I suspect the people that say the regulator can't keep up are right and people just tune around it and don't even know. I don't want to do that though.
#43
He must be using a boost a pump too with that stock pump with E85. Definitely weird how some people can go years while others only days.
#44
No there is a mechanical regulator in the tank. There is no fuel pressure sensor. Zr1s are PWMd like u described.
#45
So what's the fix for the regulator issue for the walbro 450 , I know returnless systems are good for well past 600hp so I know going return style isn't necessary
#46
#47
- Flows over 260 lph at 13.5 volts at 400 kPa (58 psi) fuel pressure. This flow rating is module output (to the fuel rail) and accounts for the flow required to drive the modules internal venturi pump, the passenger side venturi transfer pump and the pressure drop across the check valve, internal fuel filter and other internal components (fittings, lines etc.)
- On gasoline at 13.5 volts the module will support roughly 800 HP naturally aspirated (~0.5 BSFC) and 700 HP for turbocharged/supercharged applications (~0.6 BSFC)
- On E85 at 13.5 volts the module will support roughly 650 HP naturally aspirated and 500 HP for turbocharged/supercharged applications
Here's the link for the item
http://www.lingenfelter.com/product/...l#.WHu5rIY8KEe
So basically they are stating a pump only putting out 260lph will support 650hp so probably 550rwhp ? Does that sound accurate?
#50
Check this out , these are the specs from the lingenfelter drop in replacement pump system they sell for our cars
#51
Sorry to hijack your thread MTBsully with all this fuel system info but I know you've been involved with a lot of the threads I've researched involving your 450 swap and any logistics that involve this swap and supporting info so I hope it's helping us learn more , but I'll stop discussing this stuff if you wish
#52
Might try and get started on the fuel pump install tonight.
#53
Got a bit done tonight. Will finish tomorrow most likely.Drained all the fuel from drivers tank by jumping the relay. Everything was a breeze except the crossover tube. The lines stuck in the tube, as it seems a lit of people have issues with, but i cannot get the tube to pull out enough to even see them. Already removed aluminum tray below passengers side tank. Need to figure out a way to get some more wiggle room in the crossover tube.
#54
I have a brand new aeromotive 340lph stealth pump that I verified is good for e85 , on their website they said as long as you ran a inline 40 micron filter after the pump that they have seen over 1000 hours at 60psi and 13.5 volts with no issues , I'm gonna run the racetronix hot wire kit and and intermediate pump harness as well , the 340 with the wiring kit should easily be good for 600rwhp on e85 , I already had the pump new in the box for a build I did for a guy and he ended up using a different pump and he gave me this one , and I'm only speculating but I bet since it's the same size as a walbro 255 it should fit perfectly in my fuel basket , I'll still lose the line that fills the basket and the check valve but it isn't an issue with the 450 walbro so should be fine with mine , also it will be less stress on the factory regulator
#55
Theres a lil hanger that holds the cross over tube kinda in the middle. Pop it off of that to get a lil more wiggle room too. Just keep prying and it will eventually pop. I had the same problem. The hoses inside wouldn't come undone and i broke one of the locking clips. But it did finally come apart. I took a break and my buddy went under there and got it. I used a long screwdriver and a prybar to get enough leverage. No way u can do it without it.
#56
#57
#59
Another hour or so tonight and I'm just about done. Couple notes:
-Dont understand why people cut the stock bucket. I reused the original filter sock and it went back together like factory.
-I did not cut the factory fuel line that doesnt attach to the pump. Not sure why some people do?
- I may cut down my fuel line a bit more. When the bucket assembly compresses on the springs it seems that it almost wants to kink. Why does the bucket change length anyways? It appears it rests in the tank in the compressed position.
I jumpered the relay again with the harness plugged back in and the fuel tanks still outside the car, and the pump kicked on. I should be good to go.
Finally out
Crossover pipe fittings
Stock bucket
Walbro and Stock side by side. Effectively the same size
Fits in there like stock
Wiring it up.
Ready to go back in the tank<br/>
Finally out
Stock bucket
Wiring it up.
#60
From what I've read the 450 recently changed size or something and fits right in. I'll be doing mine tomorrow and will find out as well.
I'm going to be installing mine with a hydramat, but your pics give me hope that I'll only need to do slight modification to make it fit vs old threads.
