[Z06] Tips and tricks to radiator flush
are there any tips and tricks you guys can give me to do in the radiator flush? Also how much coolant in the system hold?
Drain dexcool
Fill with 2G water [takes a while for air to burp out] drain
Run engine until hot.
Run engine until hot. drain again.
Fill with 1.5G dexcool and 1/2G water
1G stays in block
MTPZ06 (02-27-2017)
ok so this is a multiple flush thing..
if i have it right the book says 11.9 qts. so drain, fill with water, run to circulate. repeat till water is clear coming out. then once i know there is only water in the block add 6 its of dexcool and then top off with water should give me the 50/50 mix i need with the water that is in the block.
sound about right?
i just wanted to make sure there weren't any bleeder screws or something i don't know about hidden somewhere.
sound about right?
sound about right?
sound about right?
The 'airlift tool' makes filling the system without air pockets easy, except it costs a bit. I use it all the time in the shop, great tool.
There are 2 drains in the block if you are so inclined.
