[Z06] Considering XPEL Ultimate...
#41
For three grand, you'd think they could throw those in.
#44
Seems prices are all over the place for what people charge. For the amount of area being covered, his prices seem quite fair from other prices I've seen. And like I said, he has a top notch rep.
As far as the mirrors attracting car doors, I pretty much never park near other cars. The spot I park in at work is by itself, and if I park in a parking lot, it will be way out away from other cars.
Mr. Jean (05-18-2017)
#45
With regard to the price he did throw in a lot of free prep/paint correction work based on the prices for each area. That is supposed to be extra as it states right on his site, but he didn't charge me much for it.
I'm sure you'll be happy with it all.
#46
Kbreeze,
Be sure to have the installer run a strip of limo right across the top of the windshield. Its a great add to kill the sun in your eyes, and here in OK...20$ extra.
kbreese (05-18-2017)
#49
"they're already done. it's partial coverage on the mirrors. too round to do it all 1 piece"
Glad to know that was included in the price. I'm assuming (hoping) the partial coverage is the main front part...
#52
You treat it just like paint, wash, wax. It is absolutely amazing how it reflects more with wax like paint does. The wrap does 80% of the mirrors, it will have 1/4" or so border that it doesn't cover. Your cost seems reasonable for the area and paint correction is a large chunk of your total. There is no better feeling than hitting bugs and everything else and using detail spray to get them off. I just had it put on a BMW I bought and the same type kit you got and it was about $1600.00. Vette was done several years ago.
kbreese (05-19-2017)
#53
The BMW with the same amount of coverage and the total is only $1600 including prep/install?
#54
I only use a detail spray (Adams) on my film. Also, when waxing your vehicle, be careful when you're applying wax near the seams; otherwise you can end up with wax residue that begins to outline those seams...making them far more visible.
#55
With regard to the seams, the only ones I will have to worry about is the partial coverage on the mirrors, because all other areas are being fully covered with wrapped edges. But thanks for the tip.
I've seen some people recommend this for the film areas:
http://www.chemicalguys.com/Clear_Se..._16.htm?ref=cj
Apparently it's made specifically for film.
What I'd really like to find is one sealant I can use on the whole car (areas with the film and paint without film) Instead of using one product/ procedure on the film and another on the paint.
#56
No sir, I did the paint correction, paint protection was $1600.00 Yes, detail spray and wipe everything off.
#57
By the way, the car is all done. Detailer just emailed me:
"Ok got some finishing touches here but overall looks good. Will be ready for the morning. Let me know your plans for pickup. Also, originally we had said $2600 then you added the rockers and I had said $3000 total (+tax which we already discussed). After cutting the material it was actually less than I thought so $2900 total is really what it should be. I'm sure you wont argue."
So, $2900 instead of $3000. That was nice and honest of him.
#58
I wax the car and use detailing spray, just like I'm detailing or waxing the paint. I've got two cars with Xpel Ultimate on the entire front clip, the mirrors, across the leading edge of the roof, the spoiler, and hallway up the door to keep rocks off the side of the ca where wide tires throw them up into the paint.
When you clean Xpel, ypu use a cleaner supplied by Xpel. I have also used their wax, but really like ot use it, or Zaino, ora couple of others. What others have said is true. Once properly cleaned and detailed - waxed if needed - the Xpel coated areas glisten and are higher gloss when you stand off from the paint and look at the car from the side.
I got lucky as my detail shop installed $3000 worth of film for $1700 as I'm letting him use the car in four car shows as an example of a film coated car...with the windows up so that no kid with an ice cream or the like can get in.
#59
I would do it asap.
I did the whole front, rockers, around the rear scoops on my gs and the mirrors.
Glad I did. The product is a self healing wrap that has paid for it's self many times over.
I don't sell it or install it, just a very satisfied user.
