[Z06] (Video) Dynamic Airfow Catch Can testing.
Supporting Vendor
Happy to field any questions this video brings up.
Challenge Series 1: Basic Crankcase Pressure Control
Challenge Series 2: 'Ebay' cans
Have a can you would like to see tested? Send it in!
No more BS, no more hollow claims, no more hype and deceptions. Major brand names preferred. #maythebestcatchcanwin
__________________
Solutions for the common gearhead #made in USA
mightymousesolutions.com
facebok.com/mightymousesolutions
#mmsolutions
Six time NMCA True Street Champions
Home of the first Twin Turbo C7Z 7.81 @ 176
3470# Stock bottom end and heads Corvette Stock Bottom End Record Holder
#mmsolutions
Could you do a test to see what recirculation of vent gasses into filter actually does on your recirc type cans?
Running mine besides the air filter unsure if it makes any difference.
MM FTW.
Had the other brands, blew seals. swapped to MM, no issues. A big power LS needs a TON of crank case breathing. Even dual 3/8" with no restriction I would see crank case pressure. Dual -1/2" was needed.
There is a reason the big power builds almost always run a MM or MM style setup.
Very interesting/impressive, David. So what you are saying is on you can at 16 cfm blowing through the #10 line and venting out through the little air filter on top it is getting 3 psi which is kind of the max you want in the crankcase. So I presume the little air vent/filter on top is not the restriction it is the #10 line and/or the baffling stuff in the can that is causing the resistance? I guess it is not as much the #10 line so much if you unhooked it, it would probably blow quite a bit of air with just the 5/8 tube before any showing of pressure. So would you say the competitors issue is more of the smaller 3/8 line which if a barb fitting goes down to like 1/4 inch in the metal part and/or the mesh stuff in theirs being more restrictive. I think the real issue with these is not so much the PCV part but the ability to blow off crankcase pressure when under full throttle conditions. Your 16 cfm can support as you pointed out quite a bit of power. Assuming 2 cfm per 100 hp for blow-by this would support 800 hp and I know not an exact science so as you stated in your video 1,000 hp is certainly possible with what you showed. Again thanks for the demo.
flame suit on
I guess I just don't buy into the whole concept of venting the crankcase to the atmosphere - besides being illegal, it's back to 1965 when you had to change your oil every 2500 miles to dump out all the combustion by-products. Not to mention the possibility of un-metered air entering the intake behind the MAF (maybe the pluming of the MM can is such that this isn't an issue).
I executed a similar design with my road race motorcycle, and although I (probably) picked up a few HP by not allowing the PCV gasses to recirculate back into the engine, I also noticed the oil became dirty significantly faster than when it was stock.
I suppose for guys with blowers making big power with lots of blow-by, or engines with poor ring seal, maybe you don't have any choice - but for most of us, I'll retain my factory-designed closed-loop system. I mean, the C7 Z06 runs a blower and they aren't venting to atmosphere to relieve crankcase pressure, what am I missing exactly?
My Elite Engineering can catches plenty of oil over time, so I know it's not a placebo effect.
/flame suit off
/flame suit off
Supporting Vendor
16cfm forward flow plus 2cfm suction = 18cfm. I can get a real figure.
-keep in mind this does not consider how much hp you gain / lose from ingesting less / more crankcase fumes at full load.
flame suit on
/flame suit off
/flame suit off
A customer of mine ran a 5.1 @ 137 (1/8 mile) over the weekend with my Gen3 can. We are talking 1500hp-ish. I agree not 'most of us'.
There are lots of cans out there that do a good job of catching oil., and lots of factory power level cars with appropriately sized factory supplied PCV systems.
Catchcan is always a good idea.
MM cans work just like factory expect when crank case pressure>flow to inlet. Then they vent the excessive pressure that can cause harm. So you get best of both world. Same or better vacuum setup at idle/part throttle, and enough flow at WOT to prevent issues.
Buddy A (04-10-2017)
Amen to that. My old setup was HCI 550whp and my old FAST intake was full of oil deposits. The top of my pistons were layered...
Can it was. After reading reviews and real world experiences I decided MM was the best option. I went with the C6 WILD setup in -10AN. The fit was perfect, the mount was great looking and the can was very well constructed.
Received 1,678 Likes
2018 C6 of Year Finalist
St. Jude Donor '10, '17
Just installed the MM catch can in mine. David doesn't just sell you what's on the shelf. He talked to me at length about my car, how I use it, what modifications I have done, and requested pictures of my intake system and where I was finding oil. He assembled one for me that addresses directly my issues. I installed it and already know it is going to help me. He even responded to a few questions over the weekend, which I appreciate. Stand up guy with a superior system.
David@MMS (04-10-2017)
https://www.corvetteforum.com/forums...catch-can.html
https://www.corvetteforum.com/forums...guys-look.html
https://www.corvetteforum.com/forums...at-a-mess.html
https://www.corvetteforum.com/forums...500-miles.html
So on and so forth...
Have you seen the threads in there about finding puddles of oil in the S/C, and how guys are plugging the PCV line routed into the S/C. Its apparently a problem...most seem to remedy with a catch can though.
I need to get my kid to hook one up on his 2017 SS. I've already warned him about the GDI nightmare, guess who will be doing most of the work to check the intake valves every 10K miles?
Got it so the increased ID/OD line sizes are key and of course the length of the line to lesser extent, are the things the installer needs to know as your Can itself is really not the bottleneck until really big hp. I have seen a couple of very simple set ups with your can where they take a valve cover opening and use a 10 AN fitting then a line going to the can.
Oh, I know the value of the catch can, my comments were around crankcase pressure. All good.
Supporting Vendor
If any of you guys have a brand name can I have not run I would be happy to bench test it (the flow test above as well as oil consumption efficincy and maximum capacity) add the data to my public library, and pay return shipping
Supporting Vendor
I have some cans coming in for testing stay tuned and get with me if you have one you would like to see stretched out!
MM oil catch can.
Today I had some time to spare checking the fluids and decided to check the MM oil catchcan that has like 2,500 miles since was mounted. I did not worry about checking it because I don't do track, just some times hit the gas pedal on the highway for short periods of time. For my surprised lucky that I had two Blue paper towels ready available in my hand just opened the drain valve and oil start to coming thru, really glad that I had installed the oil catchcan. (LS3 Supercharged)
