[Z06] Washing your Z06
I'm probably just lazy but that's how I like to keep my car and paint looking real nice.
Is the Waterless car cleaner enough to get all the dirt, bugs and grime off your car? I just feel like if you don't pre soak the car with water and it's pretty dirty then you can potentially scratch the paint if you just use waterless cleaner on it and wipe dry.
i pre soak each panel with a stronger mix of the rinseless wash from a spray bottle, let it sit while i grab my wash mit, then wash half the panel with one side of the mit, then the remaining half with the other side of the mit. after that i blot dry with a waffle towel, reapply the stronger mix, and then dry with a Rethickulus towel from detailed image
what you could do... do a paint correction on the car, after it is all nice and flawless seal it with something like Optimum gloss coat. it adds another layer of protection. 2.5 years after doing mine water still beads up like i just waxed it..... it has never been waxed after i did the sealing
Paint correction is generally limited to sanding/compounding/polishing and protecting clear coat (or single stage paint). That removes swirls and minor scratches in the top layer of paint.
Are these still a thing?? haha
this is another great thing, the less you touch and rub on the paint the better
https://www.chemicalguys.com/JetSpee..._p/acc_303.htm
Washed it for first time in 3 months
Yes, however, generally I don't drive my car in rain and don't daily drive it. It never goes out in winter, so I am usually just getting road grime, bugs and surface dust off the paint, wheels and wheel wells. In regard to the scratches, I machine clean the paint at least once a year. Both of my vettes have one numerous car shows over the years, as recently as 2015.
