[Z06] 2009 Z06 slightly rough idle?
Hey Guys,
When my car idles the RPM does not stay constant it changes by about 50 every few seconds, going up and down very slightly. When this happens I also feel a little bit of a shake through the seat.
Is this behavior normal? And if it isn't what should I look for?
Thanks!
Thanks!
Mine is 09 as well and it also idle rough same as your car and i was wondering same exact thing. If thats normal or something is wrong with it. Hopefully we will get some idea of whats wrong.
Probably has nothing to do with it, but my 07 idled a little rough for a few seconds after a clod start up. I used CRC mass air flow cleaner on the MAF sensor and so far so good, it hasn't done it since.
So I just attempted to clean my MAF. Basically I took it out and sprayed both the metal plate side and the plastic side with a bunch of MAF cleaner. I also sprayed the throttle body with throttle body cleaner and it seems my idle is exactly the same as before... what should I check next? The spark plugs? Or maybe I didn't clean the MAF properly? All I did was spray it several times with the cleaner.
https://youtu.be/nmCArolKXVc
is this normal?
However since MAF was completely removed to clean, make damned certain it was replaced properly orientated, not backwards.
Surprised how many capable people made this mistake over the years.
It's apparently all too easy to do, so recheck your work & go from there.
IF cleaner was used properly, probably isn't a dirty MAF.
Even though it may not be MAF related, I would say check to make sure you don't have a "weak MAF" model. I recall checking mine and was in the clear... https://www.corvetteforum.com/forums...light=weak+maf
Do a search using, 'MAF in backwards', turns lots of hits.
After, sifting tossing postings from the 5 previous generations.
I swear more than one member getting this wrong, supposedly very easy to do, causing weird idle etc.
One always assumes they did it properly, spend hours & sometimes $ before through pure desperation discover their mistake, and to a one they all felt stupid. I would've too, self inflicted wounds hurt the most.
Check orientation, if it's correct it ain't MAF & it's off to the next step.
Can you guys check out the video and let me know if this is normal or not?
This is what my car is doing, if this is normal I'm just going to ignore it. I just don't remember it at all in my last corvette but maybe I just missed it.
I wouldn't say that's normal, but unfortunately you can tear down your whole car trying to chase something like this. If it was me, I would do a full tuneup, change all filters and fluids, clean the maf and see what happens.
