[Z06] The clutch master reservoir on my car seems to be unattached.
How is this thing supposed to attach to the car?
I notice the master has what looks like a clip and the bracket on the car has a bump on it, but when I push it down on there it just sits on it loosely. Nothing appears to be broken off. I zip tied it on for now, but am wondering what holds it on normally.
Slides on a bracket. Sounds like maybe yours is worn out or something.
Yes, I suspect the plastic is just worn on mine. I'll take another look, but my attempts to put it back on the bracket had it just sort of loosely sitting on it. I see the bump on the bracket and the hole on the reservoir clip area, but they don't seem to be having a meeting of the minds.
Not sure I will bother doing anything other than tying it down as it appears I would need to basically replace everything attached to it if I wanted it fixed.
I wouldn't blame them if it wouldn't go back on given the car is 10+ years old, but I'm kinda surprised it is just resting on there. That said, it seems like the hood and/or surrounding items keeps it from going too far, because I just noticed it loose after doing five or six autocrosses with the car.
Not sure if there is a shim missing or what, but it does seem like it should clip on.
I figured out the problem, and I feel like an idiot. The clutch fluid reservoir has a slot in the plastic mounting tab that goes over the metal bracket and locks into place. Hopefully you figured this out by now, but I figured I would let you or any others know the reason theirs may be loose.
