[Z06] Dyno numbers low? 535whp 485trq btr4
CammedC6520 (04-24-2017)
Power falling off at 6350 rpm with that size cam sounds early to me. I see BTR 3, K501, etc builds that are still making power well past that. To me, it sounds like your OE manifold is choking the motor. Again, without the graph I don't know if its severely falling off or just slightly tapering off...
Do cats really affect the HP and TQ that much? My car is at AHP right now getting their #4 heads, ported, polished, milled, long tube headers, x pipe with high flow cats, exhaust and dyno tune. I was told awhile ago by a lot of people on here that going with no cats might only get you about 5 HP over high flow cats so I chose high flow cats. Are high flow cats at risk of becoming clogged up and affecting performance?
Good functioning cats, no problem. Clogged cats can destroy a motor quickly.
I have high flow catted X-pipe on my build and it is fine. Most K501 cams peak around 66-6700 rpm for HP. The BTR4 cam is at least as strong as the K501 so peak should be up there as well. Mine with MSD/NW102 peaked at 7100 rpm and had low torque but held it well.
CammedC6520 (04-25-2017)
#34
I thought it didn't matter much ls7 lifters have a wide range I'll get Abel at Chevrolet to check the preload for me maybe I did it wrong. If I change pushrods do I need a new tune?
#35
I said nothing about the pre-load... how did you get "check the preload" out of me saying your cam could be a tooth off which would cause reduced power, but not necessarily be far enough off to throw a code.
When you put the cam in were you dot to dot on the gears? Did you spin the motor over completely a few times to make sure the dots re lined up?
#36
#37
so you didnt answer my question about being dot to dot when you installed the cam.
Or do you even know or remember?
