[Z06] Dyno numbers low? 535whp 485trq btr4
#161
CammedC6520 (04-28-2017)
#162
The C6 Z06 Fast List
Last Updated: December 1, 2016
Bolt-Ons without Internal Engine Modification
* indicates car converted to automatic transmission
Rank~~ E.T.~~ Trap~ 60'~ Driver~~~~~ M.Yr. Details Thread Video
1~~~~ ~9.874 138.701.38 Gary2004Z06 ~ 2008 details~~ thread video
Internal Engine Mods plus Bolt-Ons
1~~~~ ~9.352 153.75 1.35 Sébast19X ~~. 2008 details~~ thread video
2~~~~ ~9.465* 139.80 1.22 stanger383~~. 2007 details~~ thread video at 2:36
3~~~~ ~9.704* 138.93 1.25 C 5 ~~~~~~~. 2008 details~~
4~~~~ ~9.803 139.44 1.41 RICKLVSLACKS1~. 2010 details~~ thread video
5~~~~ ~9.810 141.12 1.38 EGOCHKR~~~. 2007 details~~
6~~~~ ~9.827* 133.67 1.28 Beach Bum~~. 2006 details~~ thread
7~~~~ ~9.937 137.54 1.41 Jared@RPP~~. 2006 details~~ thread
8~~~~ ~9.946 141.24 1.56 MOST H8D~~~ 2008 details~~ thread
9~~~~ ~9.977 139.39 1.44 rattt g~~~~~~ 2007 details~~ thread video
#163
https://www.corvetteforum.com/forums...post1561645365
Btw I've seen this forum to many times
#164
Perhaps you should read your posts again.
Don't discount your car already. You wanted 9s. Go get 'em!
#165
Well that's what racing is. Record runs aren't done by accident. It's about properly setting up the car and driver and knowing the best track and weather conditions to run your number. Then putting it all together. Seat time, seat time, seat time. Not just parts, power, and ego.
I provided you with 10 examples of perfection you elude to being almost unattainable. Plus there are about a dozen more examples of cars less than .2 away from perfection.
It again and see what she does!
#166
Pro Mechanic
No disrespect from here to the OP specifically, but just my observation on the google generation... I have to laugh when someone asks my professional advice, but then wants to argue with me because of "what they read".
I thought my numbers from Rick's dyno were low too, but the HP curve followed what I expected out of the cam exactly.
Guessing from the specs on your cam (assuming the specs provided were accurate!), I wouldn't expect the HP to fall off where it does. When Rick said "they all do that", he might have been referring to a brief dip in the curve, but not to peak HP?
If the hollow cats don't correct the situation, my vote is on cam timing. 'Connecting the dots' is fine, if they're in the right place... no substitute for actually degreeing it.
Good luck!
#167
Good luck!
Damn I guess when I do the intake I'll check the timing. I talk to dan since the cats are out in going to take it to a dyno and check the a/f ratio. I will also install a ati pulley while I'm in there right? Under drive few more ponies lol.
#168
Dang couldent help my self but had to show my friend what this car can do! This thing is bad *** and pulls and pulls and spins and pulls! To be honest I don't see a problem with the car anymore. But I'm still going to do what you guys told me. Getting it to a dyno, different one and see what she does hooking up a a/f sensor to see if the cats were clogged could of changed it a bit. They tuned with a 02 bung in the rear of the exhaust which is dumb when you have cats because the sensors are before it.
But wow so glad to be on the z06 side! "You can keep the rari I'd rather have a Chevy"
CammedC6520 (05-22-2017)
#171
Put about 1000 miles on it already only thing I notice is in let's say I'm doing 20 mph and I'm in 3-4 and give it over 25% throttle I get back fire. I was told it was in the tune and had another tuner check it who has
Known rick for awhile told me that my tune was rushed and it was cause he squeezed me in when ever he had time.. so idk went to
The track already with my runflats ran a 127 at 12.2 spinning and misshifted third horribly
#174
You sure its a backfire and not the usual crackle/pop these car exhibit on deceleration? If you're getting a bad pop and a flame out the tailpipe...yeah, get that looked at.
#180
I just did a test run to see what I could get on the runflats for one run then was done I think I could pull low 11s with these run flats and I know 9s isn't easy but 10s are and very easy saving up for c4 zr1 rims and running some slicks on them. Just wait on it
