[Z06] Final Dyno numbers with Pics.. 2011 Supersonic Blue
It has taken about 15 months to get to this point but I think that I am finished with my build, for now. I am sure that I would easily get over 600whp with a little more aggressive cam but I am super impressed with how much NA power this car makes with such a small cam.
Here is a list of my mods:
Advanced Induction 280cc head porting with milling of.03
Replaced guided with CHE guides
OEM Intake Valves and Replaced Exhaust Valves with Ferrea Hollow 2040P
BTR 660" Platinum Dual Spring kit with TI Retainers
Chromoly Pushrods
ARP Head Bolts
Straub Bushing Trunions
Hinson C7R Chain
RPM B3 Comp Cam: 243/258, .623/.623, @.050", 114 LSA
ID1050X Injectors
Mamo Ported MSD Intake
NW 102 TB
AEM Wideband 30-0333
SLP Single Gauge Pod
160 Thermostat
NGK TR7 Iridium Plugs
Haltech 103 Intake with Beehive
Kooks Headers and Catted X Pipe
B&B Fusion Gen 3 Exhaust
Mild to Wild switch on dead pedal
MGW Shifter
DRM Bilstein Shocks with bushings lowered on Stock Bolts
Monster LT1-S Triple Disc Organic Clutch with Slave and Remote 36" bleeder.
Motul RTF 600 Clutch Fluid
Elite Engineering 1/4" Tunnel plate with Thermal ABS
Nitrous Outlet MSD Plate Kit
Nitrous Outlet Heater
Katech Belt Tensioner with Belt
Nitrous Outlet C6 Stand Alone Fuel tank with C16
Nitrous Outlet Purge Kit
Nitrous Express Maximizer 4 Progressive Controller
Custom Nitrous Switch for Arm, Heater and Purge
Lingenfelter LNC 2000 Timing Retard
Custom Billet Aluminum Nano and Nitrous Bottle brackets
SB Painted Proform Valve covers
Coils Relocated under Haltech heat shield with custom MSD plug wires
Skip Shift Eliminator
R888's for the Track
Custom Crystal Grey Powder Coated Spyders for Track
Machine Face Cup wheels with MPSS and Jake Center Caps
Eagle LED Tail Lights
Lingenfelter Clutch Stop
GM 427 Hood Emblems
HP Tuners Pro
Chromoly Pushrods
ARP Head Bolts
Hinson C7R Chain
ID1050X Injectors
NW 102 TB
160 Thermostat
MGW Shifter
GM 427 Hood Emblems
HP Tuners Pro
Very nice build and results. Now go use the new performance!
Fantastic results!
As much as I like my current cam, I have decided to switch it out for a BTR Stage 4. This cam makes great power, but I don't want to leave any power on the table since this car is not my daily driver. I have all of the necessary support mods so I should be able to get another 30whp and 30wtq by just switching to a more aggressive cam.
Let me know if anyone is interested in this cam. It is a great cam that will make upper to 580'swhp and 520wtq with support mods.
Have you looked into the RPM B3 cam?
I certainly don't want to deal with that. Looks like they don't offer any specs on their cam. After you introduced this to me I called them and they told me that they are making 620 to 630whp in their package and I am basically running the same supporting mods. Anybody have feedback on this cam or have an dyno sheet to share.
They keep the specs pretty hush hush. It's something like 24X/25X .660 lift on a 114lsa for n/a setups. That's from what I've found searching the forums.
The same tuner that had the BTR cam mess up put in the B3 cam and made 625/560 with 285cc PRC heads and e70 on a conservative tune. They are putting a B3 in another local car soon.
To get to 18 it would need to be something like 241/252 114
Looks like on their youtube channel that most of their cars on pump using this cam are at 630/550. Thanks for pointing out this cam. I think that I might do some more research this weekend but this one looks like a winner.
My setup is very similar to yours with AI heads and Mamo MSD intake and short travel Johnson lifters. My cam is 240/252 on 113. I made 625hp on Dyno jet and 575 on Mustang dyno. The B3 is 243 int and upper 250's exh on either a 114 or 116. Nice cams as I had one only on a 112. Power cam on hard about 5k rpms which is the reason I backed mine down to 240/252. Mid range and over all drivability with my ID 1050x injectors is so much better now. Brian swears by his cams, I would have him custom grind you one on a 8620 core from COMP HUC intake lobe. Just my 2 cents.
